Popeye
Posts posted by Popeye
Looking for complete package
Thanks
Any ideas where I can find this?
I'm half tempted to load the drivers for the laserpoint since it's a pcut creation too.. afraid I'll trash SB if I do.. or will it just add additional drivers to the existing list?
Thanks for the help.. now I just need to find a copy
No laser, was just going to align with the blade. UsCutter has Flexistarter 8.6 for $99.. older version but should work? scratch that..unavailable!
No, I never managed to get it to work with the equipment and software I have.
I wasn't sure if anyone tried installing the Laser Point drivers in SB to see if it would work.
Any direction on the best deal on Vinyl Master or Flexistarter?
I have a Pcut CT630 running signblazer 06. I really need to contour cut, will the drivers for a LaserPoint work?
Any suggested software that doesn't cost bunches of money that will do the job?
Thanks in advance!
Happy 4th!
Which program is better, sure cuts a lot pro or flexistarter?
Anymore information on this?
Just missed the first one but watching the others...
Thanks
I'm not having any luck finding it for that price. Any suggested vendors?
Thanks again for all the help
I appreciate the information.. do they have a support forum?
Correct.. I have Pro w/Dongle.
Another thing is the jog buttons operate the carriage and roller completely backwards.
I tried the same thing using a version of elements I have... same driver... same file. The jog buttons work correctly and after I set the reg marks and tell it next
it give another window asking for redeye offset.. I set that to 0.001 and hit cut and it does.
Not sure why they are not the same and why it doesn't work correctly with Pro..
No, I haven't... never really had a problem with the software before until trying this feature
Looks like it should work then.. do they have a trail version?
I'd like to be sure before I buy ANOTHER program
Thanks for all the help!
I'm trying to contour cut on my PCut 630 using SB Pro..
Every time I try to "cut a print" it locks up the software.
Thanks for the help
Thanks for the information.. I should be able to do the same thing with SB Pro but every time I try to "cut a print" the software
locks up..
Anyone running Flexistarter with a Pcut that contour cuts?
I have a Creation Pcut 630 with Sign Blazer Pro.
I would like to be able to contour cut different printed items. If a mounted a small
Laser pointer on my machine and purchased Sure Cuts A lot Pro.. would the laser point II driver work on my machine?
Thanks in advance for the help
I would like to be able to contour cut different printed items. If I mounted a small
Laser pointer on my machine and purchased Sure Cuts A lot Pro.. would the LaserPoint II driver work on my machine?
not that I know of.. when you install it needs a code you had to call in or email to get plus the security dongle
I have version 6.0.11
I tried that yesterday and again just now.. it still comes up and says software key not found.
Is there something else I need to change in the way of settings once the driver is loaded?
Thanks!
I have SignBlazer Pro and when I installed it on a new PC running Win7 Pro it doesn't recognize the dongle..
Any suggestions?
Thanks in advance
Mr300,
Thanks for the avatar.. I just might use it
Hoping there's a simpler way
Pcut CT630 LaserPoint drivers? Contour Cut?
in Creation PCUT Cutting Plotter Discussion
works well with VinylMaster pro and my old cutter
