livingagain75
Posts posted by livingagain75
Hi I went ahead and ordered the keyspan (arrived today) and the screw connectors are stopping the 9 pins from plugging in. I have a photo but don't see where to upload it.
Cool I just ordered one from USCutter, and a couple other supplies. Thanks for your input guys.
Thanks, I just checked its hooked up to a Sabrent serial connection. Does that make a difference?
Cause now that I think about it it was waiting for a while, then after a minute of pushing the arrows it moved to the second registration. I checked the connection a couple of times thinking that might be it.
Yes I do have the older Laserpoint. I think today I will experiment with the different drivers. I thought I was onto something when I switched to the Creation P-cut 630g driver and the alignment window appeared. But was disappointed when I realized that the arrows wouldn't move the cutter. The cutter just said waiting.
And yes I would love to upgrade to a Graphtec.
That was me showing that when I put a hold. Then send what happens.Let me try this.
when I use my default cutter send= laserpoint. It goes straight to cut. No alignment window.
BUT
If I use the driver P-CUT CT630g I get the alignment window. it work as it should. Almost. I can align the reg marks. then cut (pen)
It's way off the image. I've tried to use the knife for alignment. It worked one time.
It just seems one time it works, then the next it don't. Mind you am am talking the ct630g driver- NOT the laserpoint.
The alignment will not come up for the laserpoint.
I've tried the the other driver Creation PCUT CTN630 it don't work's for me. It too goes straight to cut. No alignment window.
I will just have to get it working with the ct630g and get it zeroed in.
I know a lot time spent responding to me. If anyone would like another video. I will be more then happy to upload a better one. I just rendered it small.
or I will make a new one. Then leave the audio so I can try to explain as I go along?
I'm in the same boat as you Gifts United, I am trying to contour cut with Flexi 11 Cloud using my LP24.
When I get my job loaded and press send it goes strait to cutting if I use the LaserPoint driver. So I went ahead and loaded the Creation P-cut ct630g and finally got the alignment window to pop up. But unfortunately the arrows won't move the cutter. And the cutter says waiting. Actually after a minute of pushing the arrow it moved close to the second registration point.
Has anyone experienced this?
Oops I just noticed I posted in the wrong section. I should have posted in sign blazer. Is there any way to move it?
Hi guys, been a while since I've posted, and I was wondering if I can get some advice. I have a 24" USCutter Laser Point, wide format printer, and a heat press that I've been using for light color transfers with JPSS. Scissors are fine for the lights, but I would like to start printing with darks.
On YouTube there's a video explaining the process using Sign Cut Pro and Inkscape. But I'm using Sign Blazer. Can this be done? What are the different steps?
In the video he has 2 separate layers, 1 for the print and 2 for the cut lines. And then I would just use SBE to perform the print (adding registration marks), and then use the cutter to determine the location of the cut lines.
Am I close? Are there any steps I'm missing or tips that anyone has? I would really appreciate it.
Thanks in advance.
That's great cause I want to practice application technique with the different colors that I already have but was worried the adhesive would harm my paint job.
Thanks Roger...
I want to put new graphics on my Mustang but am afraid the 651 will harm my paint.
The surface area will be straight and I will have the design on for 1 year.
Thank you for your time.
I will call them tomorrow, but your right Coaster, I'm sure that it will stretch enough to cover.
@Ravenwind the hoods dimensions are 60 x 62".
I have actually received samples of 3M in the past, which is one of the main reasons I want to go with them. Good customer service.
Thanks guys for your input, Bill
I am wondering, how much can this be stretched? The hood is 60" wide and so is the 3M 1080 and the Oracle 970RA. Would this be able to cover the whole top?
Thanks
I have a customer that wants the whole top of his car covered with vinyl but I only have a 24" cutter right now. Can I place the vinyl side by side and look professional? Or would I need to use one solid peace?
Thanks, Bill
A little something to add to the festivities...
Very creative, good work...
Sorry guys simple mistake. right to the right of Object Manager there is a button that toggles between - and two little windows. When you click on the minus all of the layers disappear. Kind of had me stumped there for a minute. Common sense prevails... lol
For some reason when I go into my object manager to adjust the layers there is nothing there. Just an empty box. Does anyone know how to get my layer control back? Thanks
how long does it last ? oracal 751
White and black has a 8 year warranty while the colored and transparent is good for 7 years, metallic 5 years.
Vary nice.. what vinyl did you use?
Thanks,
that was Oracle 751 Black
this is just some of the work I've done
So this must be somewhat transparent as well. Looks good...
Looks nice...
My introduction to the world of vehicle graphics...
I am trying to delete these I accidentally posted it too many times
Buy A Keyspan When You Order
in General discussion
Awesome, thanks for your help Mz SKEETER.
Much appreciated.
