STUF"N"MOR
Members
  • Content Count
    20
  • Joined
  • Last visited
  • Days Won
Everything posted by STUF"N"MOR
  1. Support is closed do to weather and I have a brand new Titan 3 sitting here I can't use. Can anyone help me? Using Vinyl Master Cut software whish came with it and after sending design to cutter spooler says done and nothing happened. Why
  2. STUF"N"MOR
    Titan 3 start up
    OK All Fixed problem after 2 hours with tec support and they could not fix so they sent ticket to Australia and said it would be 2-3 days but for some reason 3 hours later they emailed me Can you please go into the Vinyl Spooler, and from the "Settings" menu, ensure that "Force Position" is NOT selected. If it wasn't, go to the connection tab in the vinyl spooler and temporarily change the Port method to "Windows Port" and select "File". Select the file that had the problem and click "Cut now". Instead of sending the data to the cutter, it will prompt you to save a PLT file. Email this PLT file to tbtech@iifuture.com and we will check the cutting data that would be sent to the machine to rule out any software settings for you. But the force position was checked so I unchecked it and tried it and guess what it worked just fine. It didn't even occur to them that it might be checked. So I am a happy camper now. Thanks to all that tried to help me.
  3. STUF"N"MOR
    Titan 3 start up
    DOES ANYBODY KNOW WHAT IT MEANS WHEN YOUR CUTTER SAYS OVERSIZE RESET I MADE MY DESIGN 4 INCHES BY 4 INCHES
  4. STUF"N"MOR
    Titan 3 start up
    signblazer has no cutter option for Titan 3
  5. STUF"N"MOR
    Titan 3 start up
    yes I did even tried 12 inches
  6. STUF"N"MOR
    Titan 3 start up
    Last night I got it to work by using a different software I was using Vinyl Master Cut that came with it, so I switched over to Sure Cuts A lot I had with my Scan N Cut and it worked perfect but I am limited on 12" wide I think but will keep working on
  7. STUF"N"MOR
    Titan 3 start up
    1/2 credit card width and a little more you barley see it
  8. STUF"N"MOR
    Titan 3 start up
    vinyl is 1 1/2 inches from right side still says oversize I guess I will have to wait until support open just sad I have brand new cutter that won't work lot of money wasted. Thanks again for all your help
  9. STUF"N"MOR
    Titan 3 start up
    it is communicating now but machine says oversize and to reset can not find any place to change size thank you for you help so far
  10. STUF"N"MOR
    Titan 3 start up
    2 x 4 inches yes set origin cutter is 28inches
  11. STUF"N"MOR
    Titan 3 start up
    ok I put new cable on still did not recognize, after several times if finally did but cutter stopped on far left and says oversize please reset
  12. STUF"N"MOR
    Titan 3 start up
    The red is just the color of the square if I change to blue it changes no writting
  13. STUF"N"MOR
    Titan 3 start up
    sorry that one black should not be there and they are reversed
  14. STUF"N"MOR
    Titan 3 start up
    here are some more of machine itself
  15. STUF"N"MOR
    Titan 3 start up
    here are some pictures on settings for software and pictures of titan 3 itself maybe I messed something up
  16. STUF"N"MOR
    Titan 3 start up
    cutter display is online, it does the test just fine I will try to get some screen prints of settings
  17. STUF"N"MOR
    Titan 3 start up
    I have watched every video and read the manual several times no help. I do realize I am new to this kind of cutter but it worked for 1 design of heart but nothing since
  18. STUF"N"MOR
    Titan 3 start up
    yes it does then I say ok and it moves down to done
  19. STUF"N"MOR
    Titan 3 start up
    I just picked a square off of the shapes to start with I did a heart 1st and all worked great then 3 days latter did a square and nothing works
  20. STUF"N"MOR
    pinch roller don’t move mh 871
    I just bought new Titan 3 and all pincher rollers are very hard to move unless I loosen screw on bottom and still hard but doable
