Worble7
Days Won
3
Posts posted by Worble7
22 hours ago, MZ SKEETER said:This is my Cutting Controller for my machine. All settings are on it. I change right from my computer. The cutter has to be sitting there ready to cut, (on mine) or it will not even open. That cutter has a different design of cutter controller. Those are not my actual settings. picture was taken years ago. The rest you can read and figure out on your own.
Thanks MZ SKEETER I see wow that's way differnt. Some of it is still in the software on mine.
22 hours ago, darcshadow said:The backing paper doesn't break the blade tip, that happens from too much blade being exposed and too much force. Doesn't take much to break a tip, and it's not something you can usually see with the naked eye.
Thanks Darcshadow
I'm using graphtec PRo studio.....So you use the setting in there for force/offset/and all that?
Thanks I will go look for there site and buy 5 maybe 10 at this rate lol do you have a link and does your take the same blade?? Thanks
Also What blades do you use MZ SKEETER?
Ok I will read and get into normal mode and show my cuts then. Thanks
I'm in simple mode I think I should be in normal mode. I will let you know after I read and get in normal mode. Thanks for the help
MZ SKEETER,
Should I do my setting elsewhere?
That's where I set my force and speed in simple mode.
So Will the backing paper break off the blade tip as I never went through the paper? Also are there better blades? I did take the blade holder out again and tested it and your right it was too long not by much. Here are my new cuts and it still has a tab sticking not a clean cut the triangle cuts clean I circled the area that is not all the way cut. Thanks
4 minutes ago, MZ SKEETER said:Until you get your test cuts correct, it never will cut right. Are you sure the blade tip is not broken off? Nothing is right about those test cuts. Plus you are cutting way into the wax paper backing. You should just barely see a slight mark on the wax paper backing.
MZ SKEETER,
It's A brand new blade I know it looks way wrong nothing smothe about it. Here's a pic of the settings I have and the blade I'm using. Thanks Jeff
Hello Everyone,
Yes I have read and adjusted my cutting blade right as long as there no position you need to set the blade in carrer and the holder I just drop it in and tighten. So my problem is when I weed my project the vinyl does not come off clean there a snap at the last spot coming off the backing. So I put a brand new blade in thinking that blade was worn. same thing and ever worse as it;s not cutting right. see pic please. Also my setting are on simple mode outdoor vinyl the force is defalt at 12 and the plus is set at 0. Thanks Jeff
I know it's something simple I'm missing but I can't put my finger on it......This is what the cut screen looks like after I did both colors and still not showing up in cut. I have 4 windows as where i think I should have 2 correct? I come and tinker every few days so I don't lose my mind. Thanks Jeff
Mike,
I'm not getting it ugh I will be steping away from the computer before I smash it lol i will take a break and come back later. Thanks for your help. Jeff
Ok I'm missing the copy part where do I copy it from the cut/plot area??
Also when should I put the marks/shape in to the image? I did it after I used inkscape to vectorize it. Jeff
Mike,
when you say copy the marks where do I copy them from?
Alignment marks as to line up multiple vinyl
in GraphTec Cutting Plotter Discussion
Thanks Wildgoose and everyone that help
