All Activity
This stream auto-updates
- Yesterday
jacksoncr joined the community
- Last week
darcshadow started following Titan 3 Alignment (Contour Cut issues)
darcshadow replied to MrClingMutohQueen's topic in TITAN Series Vinyl Cutter Discussions
If it was working fine before the computer crash then it's unlikely to be a problem with the cutter and more likely an adjustment in the software some place. Have you recalibrated your software, does say a 4" square truly come out at 4"? -
That was my thinking as well. But the whole process is so much faster and easier with a higher end cutter. I was like you, and completely understand your stance. Until you experience a good cutter it's hard to comprehend how much better they can be. Engineer here as well, and I too hate throwing stuff out that I know should be a simple fix. Best of luck, just don't throw too much money at it.
Adjusting The Weed Box Size
haumana replied to tony@highcalibercustomcoat's topic in VinylMaster CUT, LTR, PRO & DSR
personally, i usually just make my own weed boxes, because I like to be able to draw in the relief lines where they make sense on how I weed things. -
Align Cutfile Wizard freezing/Not Responding
Guest posted a topic in VinylMaster CUT, LTR, PRO & DSR
Hello i recently just got my Mh 871 Vinyl cutter and Im in the process of trial and error on trying to cut stickers. i can get the program to send to printer does that fine I load the stickers into the cutter and start to align the alignment marks I go bottom right 1 inch off and click next... Then the Program freezes only (Align Cutfile wizard) The rest is still responding any tips on how to fix would be awesome -
tony@highcalibercustomcoat started following Adjusting The Weed Box Size
tony@highcalibercustomcoat posted a topic in VinylMaster CUT, LTR, PRO & DSR
Hey There, I am having trouble figuring out how to adjust the size of the weed box. Let's say I have an image that is 2" square when I hit the "add weed box" tab it makes the box about 2.5/2.75" How do I make the weed box small so that it is closer to the size of the image and I don't waste as much material? Thanks for your help!!! -
MrClingMutohQueen posted a topic in TITAN Series Vinyl Cutter Discussions
So about a month ago our computer crashed and we had to update and reinstall vinyl master on our new hard drive. I have been having issues with calibration. I called support and was told to possible change the carriage. A tech came out and changed the carriage however my laser arms and alignment are still cutting off my image. Is there not anyone in Dallas that knows this machine to help when your contour cut of an image is not cutting correctly? We have a hanging project until I can figure this out. -
The MH does everything I want it to do if I'm scrupulous about the adjustments. I've now found another MH locally for the price of a new motherboard. If I can find the room, the old one will get its own laptop and be used when 1 inch/sec is appropriate. The engineer in me still wants to replace that motherboard...
And at $100, I'd look at a new/new to you cutter. You can find some pretty good used cutters pretty cheap. I'd read on here for years people talking about how much better higher end cutters are and I always thought how much of a difference could there really be. I'm here to say, there is a huge difference. I went to a graphtec I found used and it was night and day difference. Detail designs were no longer a fight to weed. Thicker stuff like glitter cut amazingly well. I did a design on the MH and weeding took me over an hour because of the glitter vinyl I hated working with glitter vinyl. Same design with the graphtec and I was done in like 5 min. I couldn't believe it. Don't be afraid to walk away from the MH and get something better. From what I've heard, even the SC is a big step up from the MH.
Sorry to hear that your cutter is not 100% up to speed. Keep in mind there were several versions of the MH motherboard produced, make sure you get the correct one. ( US Cutter doesn't stock all of them, just the one marked 2011C ) and it's $100 including shipping.
Since the control switches weren't working, I replaced the switch sub board. You're probably right - the next replacement would be the motherboard...although my machine has always had a separate ground to prevent static discharge.
" a replacement board " -- which board? The actual keypad itself? The motherboard? Circuitry on the MH is prone to static zapping through the chassis and more often than not, it's the Z-chip (blade up and down) which gets fried. I haven't heard of what you're describing, but it's likely a failure of some other component on the controller board (i.e. - MB) How much $$ are you into this thing? A used MH isn't worth very much, and if you can't live with the snail-pace of cutting, just consider popping for a SC or LP3 model and get on with your 800-speed (top speed) life.
Since I got it - used - my MH871 has come up with 24 i/s and 100g. This has proven appropriate for everything I do. Suddenly, those settings changed on startup. I was able to change the force, but speed is stuck at 1 i/s and the buttons won't change it. I purchased a replacement board and installed it - no change. The cutter still works fine, but is obviously REAL SLOW. Thoughts?
- Earlier
How do I do a node edit on an image ie a photo. I did it befrore now I cant remember
slice&dice replied to cousinit75's topic in General discussion
We operate in a world consisting of two types of graphics. Raster and Vector. The first is composed of Pixels, the second is made up of Nodes. (paths) Start with that knowledge, and work from there. -
darcshadow replied to cousinit75's topic in General discussion
You can't, photos are not made up of nodes. You can only node edit vector files. If you have a photo, you can vectorize it, and then edit the nodes. What software are you using? -
cousinit75 posted a topic in General discussion
Hi everyone ,how do I do a node edit on a photo? I managed it before now I cant remember,thanks -
Hello i am not an expert but is it possible to compare a Silhouette (that was for me an instagram product: "ouah i love it!" "it's my new best friend!") with Graphtex or Roland ? I have purchase a Secabo, that is a German product but in fact certainly a classic Chinese rebranded, but i am "a bit" satisfied, and for the price without reading yet other posts on the forum (that i will certainly do in the near futur), i really thought Roland is a good light and cheap choice.
On a Windows computer, it's very easy also to create a scheduled task with a script. Create a text file you name for exemple Backup_VinylMaster.cmd (.bat or .cmd means batch file). inside this text file : robocopy "C:\ProgramData\FutureCorp\VinylMaster_USC\Cutfiles" "E:\Backup-VinylMaster" /E /R:1 /W:1 And add this file to your windows "task scheduler" to start everyday. Regards, Letizia Casanova
Fabich started following Cerakote Stencil, reusable stencils, MH series as a stencil cutter and and 2 others
Thank you for your links. I am installing a module on my prestashop E-shop to allow customers to visually add images or text on a T-shirt, this module uses Google fonts. Then i just discover Google propose some fonts, nothing is really fantastic but they are free for commercial use : Browse Fonts - Google Fonts https://developers.google.com/fonts/faq#can_i_use_any_font_in_a_commercial_product Here is the module : Ecommerce product customizer for visual custom products. | Kickflip (gokickflip.com) With the demo for example : T-Shirt – Kickflip Product Configurator Examples (gokickflip.com) --------------------------------------- leticasanova.fr
Sorry, when answering i mistake and answered to another similar question : ------------------------- Leticasanova.fr
Hello, by my side i do not use this kind of pillow as i was not sure of the density, and then was afraid to lose too much pressure. I purchased silicon pads 8mm (format 12" x 15" / 30cm x 38cm) for 25€ each. It's almost the same density as the press pad. It does not perfectly absorb the buttons or zip, but you can cut a groove or lunge (translator) for your polo shirt collars for exemple. ------------------------- Leticasanova.fr
Ho ! Thanks for the tip, looking for the word "ground" on the forum there are a lot of information. By my side i encounter no problem but by security i will connect my plotter stand to my steel desk stand (or "legs"), even if my plotter is already connected to the power ground and to the stand (yellow cable). Grounding without a Stand - MH Series Vinyl Cutters - USCutter Forum Another way to ground your cutter - General discussion - USCutter Forum I did not imagine what kind of problems we can encounter if we don't ground the plotter : my plotter does not cut and has no pressure - MH Series Vinyl Cutters - USCutter Forum ------------------------- Leticasanova.fr
I've tried different vector software, and so far, I've found that Inkscape produces the cleanest results, truer to the raster image than other vector engines. The only other software that I found to be better is Vector Magic, but Vector Magic is not free, but it can do colors. You can give this a try since you're getting into embroidery: https://inkstitch.org/
Thanks a lot, i have already installed the program but the drawcut (vinylmaster) was from now the easiest and fastest way. I have also to use inkscape has i i am start embroidery and the embroidery software is a bit light in vector process. ---------------------------------------------------------------- Leticasanova.fr
e-thrist changed their profile photo
Graphtec CE7000-60 Making Multiple Passes While Cutting
haumana replied to Super Dave's topic in GraphTec Cutting Plotter Support Requests
an alternative would be to post one of the files, so another forum member can try cutting it and seeing what kind results we get. i agree with skeeter to see if another software will do the same thing. -
MZ SKEETER replied to Super Dave's topic in GraphTec Cutting Plotter Support Requests
Did you ever try a different cutting software other than Studio 2? That way you can figure out hardware or software problem. Signcut has a trial. Sure cuts a lot has a trial.
