July 30, 2010, 02:14:11 AM *
News: If you are having issues with a cutter, heat-press, printer, and or vinyl goto http://support.uscutter.com/  and read the knowledgebase, check out the downloads, or submit a ticket for a quick resolution.
Pages: [1]   Go Down
  Print
Author Topic: Instead of just a standard outline  (Read 938 times)
malamute
Newbie
Offline Offline
View Profile
« on: February 28, 2007, 08:32:55 PM »
Instead of a standard outline that Artcut outputs to the cutter, is there a way i may be able to adjust some setting where after it cuts the project, it cuts it again a 1/4", or whatever i'd like, inside the image again. For example, if I output a simple circle could I make it cut a ring a 1/2" wide instead of just a disc?
Logged
billy hughes
Super Hero Member
Offline Offline
View Profile
« Reply #1 on: February 28, 2007, 08:35:15 PM »
You would have to make the smaller cut a different color and run it as a two color job.But I don't know how to tell you to get there with artcut because I've never used it.
Logged
gamblerbodydesigns
Newbie
Offline Offline
View Profile Email
« Reply #2 on: September 28, 2008, 09:46:06 AM »
in the advanced tab there's an "inline/outline button . havent used it yet as i'm still fighting with vector image imports lol but give it a go
Logged
Pages: [1]   Go Up
  Print
Jump to:
