kenimes
« Reply #30 on: June 01, 2009, 12:36:57 PM » |
Well, no way to install it through UBS. I borrowed a computer with com port and it works but the trouble is not solved. I gues I will try to sell it and forget it forever (what I really want to do is burn it on fire). How many time losted...
One more thing, SignBlazer is unable to run with the cutter, always errors of any type. No problem with SignCut X2 trial.
Or, if it is still under warranty, submit a support ticket to USCutter: www.support.uscutter.com
Logged
Kittycut
« Reply #31 on: June 04, 2009, 10:38:16 AM » |
Thanks. First I will try to do the job as I can.
Logged
Marko9191
« Reply #32 on: August 17, 2009, 01:57:00 PM » |
This was very helpful. Thank you!
Logged
jstovson
« Reply #33 on: September 19, 2009, 04:33:37 PM » |
My email is jstovson@loretel.net , my cell is 701-429-0001. I just posted this yesterday. Don't know what's wrong with this - I have vista, I downloaded the new driver, connecting with usb, use signcut and signblazer, bought it about 2 yrs ago. It worked just fine with my old computer, but got the new one and the best I can do is make it roll out all my vinyl! I've been dealing with this for about 2 months and I'm tired of it!!! PLEASE HELP!!!!! Starla I reinstalled signblazer today - that didn't help. I can't reinstall signcut because I used up my last three installs trying to get it on the new computer. I stupidly took it out of the old computer before I made sure it worked in this one. I think I bought it in Jan or Feb of 2007. It worked wonderful untill I tried to hook it up to the new computer - don't know if its vista or usb. I have to hook it up usb because I don't have the com or lpt hookup on my new computer. Thanks for your help. Starla
Logged
kenimes
« Reply #34 on: October 03, 2009, 03:31:24 AM » |
Starla- if your new Vista computer has an open PCI expansion slot on the motherboard (which it should)- invest in a $7 9-pin Serial PCI expansion card, add it to the new computer, and do not frustrate yourself trying to configure USB with an MH series on Vista. No drivers to fuss with when using 9-pin Serial. Just use the 9-pin vanilla colored cable.
Logged
jstovson
« Reply #35 on: October 10, 2009, 12:27:08 PM » |
Thanks kenimes - I did get it to work finally (no idea how). I will remember that cord for the "next time" lol. Thanks for everyones help - Starla
Logged
gamudslinger88
« Reply #36 on: March 15, 2010, 09:34:19 PM » |
Another Vista user with problems here! I bought my MH721 about 3 years ago and used it every day on my old Dell PC via com cable. I stored the cutter for a while and just took it back out to start cutting again, figured I would use my new Dell PC with Vista and the USB. I can not get my computer to reconise the cutter. I have tried Flexi 8 starter and Artcut but no luck. When I send something to cut and I click on the pending printer icon at the bottom of the screen I can see it pending but it shows that USB001 is "offline". I have tried both drivers listed on US Cutters downloads but neither work. I can put a com card in my new Dell PC but I want to run the cutter on my Dell laptop as well. Its easier for traveling. I am at a point where I am stuck. Anyone have any tips to help me get this going?
Logged
Dakotagrafx
« Reply #37 on: March 15, 2010, 11:16:42 PM » |
Logged
Graphtec CE5000-60 , SBE, Flexi, Illustrator, Sunie Heat Press ''Many of life's failures are people who did not realize how close they were to success when they gave up.'' -- Thomas Alva Edison
gamudslinger88
« Reply #39 on: Yesterday at 10:47:00 AM » |
OK I got it. When I changed the port in production manager it didnt take and I didnt go back and check. OOPS:) Got it working now though. Hope I can get it going on my laptop without any issues now.
Logged
Dakotagrafx
« Reply #40 on: Yesterday at 12:10:04 PM » |
glad you got it going!
Logged
gamudslinger88
« Reply #41 on: Today at 04:24:31 PM » |
Well I did. I cut out a few pictures playing with the pressure and all, today my vinyl came in and now it will not cut anything. I am about to call tech support.
Logged
Speedoggy
« Reply #42 on: Today at 04:27:58 PM » |
what version of Flexistarter are you using? 8???
« Last Edit: Today at 04:45:34 PM by Speedoggy »
Logged
Graphtec FC7000MK2-75 Flexistarter 8.5 Toshiba laptop Windows XP
gamudslinger88
« Reply #43 on: Today at 09:37:47 PM » |
Yea Flexi 8 Starter. I called tech and they fooled around with flexi and my settings but everything was right on. They had me reset the cutter and it worked fine. It works now but I have to reset the cutter after every cut. I have to pull the USB cable out and then shut the cutter down for 15 seconds then turn it on and then plug in the usb. Im going to try the free download of Signblazer and see how it does. I am thinking maybe flexi is too complex of a program for my simple minded cutter.
Logged
Speedoggy
« Reply #44 on: Today at 10:07:14 PM » |
once again, which version of Flexi 8 are you using? 8.1, 8.5 8.6? There are several versions which are you using?
Logged
