Yones12
« on: November 21, 2009, 12:28:06 PM » |
I'm using a Refine 871 and I'm cutting in flexi 7.6v2, I'm using usb to connect it and when the job gets to 39 percent it says write port error, it keeps cutting for a couple more minutes then it stops, Anyone help i need to deliver this sign TODAY!
« Last Edit: November 21, 2009, 12:34:48 PM by Yones12 »
Logged
Refine MH-871. Flexi.Inkscape.Adobe illistrator.Bad A$$ Computer.Getting heat press soon. I LOVE CUTTING
Speedoggy
« Reply #1 on: November 21, 2009, 12:40:48 PM » |
What version of windows are you using? I also have Flexi, maybe this will help you,,, go into the Production Manager and change the Packet size to 1000 KB, you will have to actually erase and enter the 1000, click apply and ok, or try reinstalling flexi
« Last Edit: November 21, 2009, 12:45:00 PM by Speedoggy »
Logged
Graphtec FC7000MK2-75 Flexistarter 8.5 Toshiba laptop Windows XP
Yones12
« Reply #2 on: November 21, 2009, 12:54:35 PM » |
Im using xp home. I tried everything, it cuts and then will give me a write port error, i've wasted so much vinyl.
Logged
JoeDirt
« Reply #3 on: November 21, 2009, 12:55:54 PM » |
how big is it? not enough memory?
Logged
Cutter: an exacto knife and a steady hand Software: MSPaint, and crayons Heat Press: griddle and an iron _ I quit smoking cigs on 12/22/09
Yones12
« Reply #4 on: November 21, 2009, 01:03:27 PM » |
Its a menu board that is 21.669 x 22.888in
Is that to big?
Logged
Yones12
« Reply #5 on: November 21, 2009, 01:12:23 PM » |
Okay i just cut again, with baud set at 4600 on my cutter and in flexi, i unchecked the box for the disable "connect to local production manager using TCP/IP", and it cut so right now im good for now. Thanks
Logged
JoeDirt
« Reply #6 on: November 21, 2009, 01:13:45 PM » |
good deal, ya know I had to change my baud settings once too now I only cut on 4800
Logged
Yones12
« Reply #7 on: November 21, 2009, 01:15:51 PM » |
Yeah, What is baud setting anyhow?
Logged
JoeDirt
« Reply #8 on: November 21, 2009, 01:21:15 PM » |
I think its the speed the computer talks to the cutter, remember the old dial up connections they had baud speed.
Maybe not sure.
Logged
Yones12
« Reply #9 on: November 21, 2009, 02:19:53 PM » |
Well I'm only 16 but i understand what your saying.
sorry for the late response i was weeding and applying this menu board
Logged
JoeDirt
« Reply #10 on: November 21, 2009, 02:28:21 PM » |
16 wow awesome let me know if you need anything else as far as flexi, graphics etc... to keep you going or get you into some new stuff. What part of michigan
Logged
Speedoggy
« Reply #11 on: November 21, 2009, 02:36:48 PM » |
found this What is Baud? Contrary to popular belief, baud is not a direct measurement of data transfer speed, but instead it measures how many electrical signals are sent per second. Baud is used to measure the rate of electrical signals, or "signaling elements," for modems, networks, serial cables, and other data transfer mediums.
Logged
Yones12
« Reply #12 on: November 21, 2009, 02:44:32 PM » |
I'm in Livonia about 15 minutes from Detroit. Yeah i will ask away if needed. Trying to get all the business i can get. Well thanks for all your help. I'm off to drop these signs off. Have a Great weekend and a great Thanks Giving
Logged
JoeDirt
« Reply #13 on: November 22, 2009, 07:17:01 AM » |
oh yeah i know the area we used to live in westland then canton until we moved to God's country the UP!
Speedy thanks for the info!
Logged
Yones12
« Reply #14 on: November 23, 2009, 04:38:11 PM » |
Gotcha, yeah I'm pretty much in westland every day, its getting bad now though.
Any good hunting up their?
Logged
