March 18, 2010, 08:58:16 PM *
News: Happy New Year - The best forum on the planet is another year older!
Pages: [1]   Go Down
  Print
Author Topic: Flexi Offset  (Read 349 times)
John Thomson
Member
Offline Offline
View Profile
« on: November 20, 2009, 06:23:29 AM »
What blade offset do you guys that run a Refine with Flexisign use?
John
Logged
Yones12
Hero Member
Offline Offline
View Profile Email
« Reply #1 on: November 21, 2009, 12:26:07 PM »
I run a .23 offset
Logged
Refine MH-871.  Flexi.Inkscape.Adobe illistrator.Bad A$$ Computer.Getting heat press soon.
I LOVE CUTTING Smiley
John Thomson
Member
Offline Offline
View Profile
« Reply #2 on: November 21, 2009, 03:59:47 PM »
Been messing with this setting today and for me 0.27 seem to be spot on with my MH 871......I have a 1351 as well so will try and get that perfect tomorrow.
Would the blade manufacturer influence this setting?
john
Logged
Cable Tech
Sr. Member
Offline Offline
View Profile Email
« Reply #3 on: December 04, 2009, 10:03:29 PM »
I'm running .13 offset on my 721 and Flexi and that seems to be the sweet spot on my machine.
I am using a 60 blade. I think the offset is the same on a 45 and 60 if i remember right?
Logged
US Cutter MH 721 | 24" | XP | Serial | Flexi | Signcut | Inkscape | Knight Jetpress 14 Heat Press
Dakotagrafx
Super Hero Member
Offline Offline
View Profile
« Reply #4 on: December 07, 2009, 12:37:58 AM »
offset should be different on 60 and 45 - can even change as the blade wears
Logged
Graphtec CE5000-60 , SBE, Flexi, Illustrator,  Sunie Heat Press
''Many of life's failures are people who did not realize how close they were to success when they gave up.''
-- Thomas Alva Edison
MrMopar64
Hero Member
Offline Offline
View Profile WWW
« Reply #5 on: February 04, 2010, 11:37:54 PM »
I'm running .10 MH721 and Flexi
I'm also using a 60 blade
MM64  Cool
Logged
Windows xp, USC MH721 on USB, Illy CS4, Flexi Pro8.1v1
FireMalt
Super Hero Member
Offline Offline
It is what it is...
View Profile Email
« Reply #6 on: February 04, 2010, 11:41:14 PM »
To be honest with you... each machine is going to be slightly different. What works one person's machine may throw yours way of course. It's just one of those you have to play with and fine tune the machine to your liking. IMHO
Logged
GraphTec CE5000-60|Flexi Pro 8.1|16"x20" Mighty press| Pcut 24" cutter as a spare.
sarconastic
Super Hero Member
Offline Offline
View Profile WWW
« Reply #7 on: February 05, 2010, 09:45:08 AM »
+1 Firemalt.  Thumbsup that's while all blades come with a .25 offset "Starting" point. You then tweak one way or the other to make your machine cut better.
Kevin
Logged
"I may have said it, but you can't prove I meant it."
Laserpoint 24", FlexiSIGN PRO 8.1, SignBlazer, Inkscape, 6 in 1 Heatpress.
Pages: [1]   Go Up
  Print
Jump to:
