March 17, 2010, 03:22:45 PM *
News: If you are having issues with a cutter, heat-press, printer, vinyl, and or anything else we have sold you request support. Goto http://support.uscutter.com/  and read the knowledgebase, check out the downloads, or submit a ticket for a quick resolution.
Pages: [1]   Go Down
  Print
Author Topic: Need a little pricing help...  (Read 309 times)
reelguitars
Member
Offline Offline
View Profile Email
« on: November 18, 2009, 01:10:05 PM »
OK guys...I'll try to explain this as quickly and efficiently as I can.  I have a customer who wants a 4' x 4' sign made as such...1/4" plywood sealed and painted on both sides.  He then wants the sign done like the small mock up I did in 651 Oracal.  He is not negotiable on the substrate.  Then...he has another piece of a sign that has a 4' x 8' sheet of plywood on it.  I will have to sand off old painted letters, reseal, repaint, and then do the sign like the large mockup, also of Oracal 651.  Then, I will have to duplicate that sign for the other side on a new sheet of plywood.  I generally do smaller things, I want to charge fair, but I don't want this to be a giveaway.  All feedback is carefully read and certainly appreciated.  Thanks in advance for your help.  David...
ps...cut the top of the arrow off when I printed...
« Last Edit: November 18, 2009, 01:17:16 PM by reelguitars » Logged
MH-721, MH-1351, HP 9800, 15 x 15 IllumaPress, a bunch of vinyl, and "ain't skeered" to try new things.  My sort of finished website at Go Daddy...http://www.dcsignsandgraphics.com
ff958
Hero Member
Offline Offline
View Profile
« Reply #1 on: November 18, 2009, 05:32:07 PM »
I would think about how long it is going to take to sand the old sign vs. just buying a new sheet. Can't really help on the price tho. I quoted a 4x6 4 color @ 425 installed and had one guy beat my price by 100.00. Huh?
Logged
IAFF Local 2008
MH-871, PCut 630, Sign Blazer, Flexi Starter,
We make Domed decals.
mars
Hero Member
Offline Offline
View Profile Email
« Reply #2 on: November 18, 2009, 08:15:31 PM »
Ok I plugged it into my estimating program
I used 1/2" plywood cause I don't have a price set up for 1/4".  Price for quote purposes is $50 a sheet including markup.  I added 40 minutes for sanding and prep on old plywood substrate which wound up being a little cheaper than the $50 for another sheet of plywood would have been.  I came up with the following
4' x 4' using new plywood primed painted and sealed 3 colors of vinyl  2 sides  $188.54
4' x 8' sanded down and primed painted and sealed 3 colors of vinyl  1 side     $287.80
4' x 8' using new plywood primed painted and sealed 3 colors of vinyl 1 dside   $293.40
        total $769.75
Attached is a .txt file  of the hard numbers report
-mike
* 1118estimate.TXT (1.1 KB - downloaded 21 times.)
Logged
midwaste
Super Hero Member
Offline Offline
View Profile
« Reply #3 on: November 18, 2009, 09:32:21 PM »
I can guarantee you that it is going to be more economical for the customer, and more profitable for you to use a new piece of plywood for the sign, rather than sanding the old sign.  You should be able to get a good sheet of plywood, sanded both sides for around $20.
It's going to take more than an hour to sand, clean, prime and paint the old piece.
If they insist on using the old piece, I would tell them $50/hr for labor, period.
Logged
reelguitars
Member
Offline Offline
View Profile Email
« Reply #4 on: November 19, 2009, 03:58:57 AM »
Friends...thank you so much for the help.  I needed to get this estimate out this morning.  I feel like the guy will jump on it.  I hope so.  Wanna see a bad ride???  Check out the car my friend and his son built at my little web site...www.dcsignsandgraphics.com.  I cut paint masks for the graphics like on the side of the car.  Once again, I appreciate all your help.  DC
Logged
Pages: [1]   Go Up
  Print
Jump to:
