Speedoggy
« on: November 18, 2009, 12:46:07 AM » |
trying to help a friend.. who has a Graphtec CE50000 2009 unit, How do you disable the media sensor on your unit? I have FC7000mk2-75 and they have different buttons and etc. for how to use the machine. I'm sure someone out there with a CE5000 newer 2009 unit can help him out. Maybe I am calling it the wrong name, BUT I disable the MEDIA SENSOR on MY unit, to stop the machine from doing the premeasure of the WIDTH of the piece of vinyl in the machine, before cutting, then tells you what the cut area is. Is it called MEDIA SENSOR on the CE5000 series also? thanks in advance..
« Last Edit: November 18, 2009, 09:58:47 AM by Speedoggy »
Logged
Graphtec FC7000MK2-75 Flexistarter 8.5 Toshiba laptop Windows XP
Signs and Designs
« Reply #1 on: November 18, 2009, 04:26:08 AM » |
put a small piece of vinyl over the sensor
Logged
Speedoggy
« Reply #2 on: November 18, 2009, 09:40:31 AM » |
bump
Logged
Dakotagrafx
« Reply #3 on: November 18, 2009, 10:42:47 AM » |
I believe the CE-5000 uses magnets in the hold down wheel assembly to measure width so it would be harder to fool this sytem
Logged
Graphtec CE5000-60 , SBE, Flexi, Illustrator, Sunie Heat Press ''Many of life's failures are people who did not realize how close they were to success when they gave up.'' -- Thomas Alva Edison
Speedoggy
« Reply #4 on: November 18, 2009, 10:59:06 AM » |
ok now here is the User manual,, and on page 5-3 at the END ....Special functions enabling/disabling HOME SENSOR Does this stop your machine from measuring the width of the vinyl in your machine? And how did you get there? http://www.sc-x2.com/files/man/graphtec/CE5000E.pdf
Logged
tekcorps
« Reply #5 on: November 18, 2009, 11:08:21 AM » |
Section 4.11?
Logged
Panther • Puma II • Weeder • Mighty Press • Flexi Pro • Illustrator • Photoshop • Inkscape • Windows XP
tekcorps
« Reply #6 on: November 18, 2009, 11:18:13 AM » |
Looks like, hold down key until menu shows up, then up and down to navigate menu. Find Home or Media whichever you want to disable and then use prev or next button to select enable or disable.
Logged
tekcorps
« Reply #7 on: November 18, 2009, 11:20:32 AM » |
Logged
Speedoggy
« Reply #8 on: November 18, 2009, 11:23:26 AM » |
sorry that is not it.. EXAMPLE< When a 15" width piece of vinyl is put into the cutter, the machine does a premeasure, of moving the carriage head from the right side of the vinyl to the the left side of the vinyl, and gives a cutting area of 13" So actually it is loosing 2 inches of vinyl. We want to disable that and it appears to be the HOME SENSOR in the use manual, So, are any of you using that and how did you disable it?
Logged
Speedoggy
« Reply #9 on: November 18, 2009, 11:25:33 AM » |
OK, MY friend said when he Pushes on the ORIGIN and ENTER BUTTON at the same time, it does Nothing. Does this work for you?, then you can Use up and down arrows and scroll for these functions?
Logged
Speedoggy
« Reply #10 on: November 18, 2009, 11:33:12 AM » |
yes I showed him that before, he does not understand the part that says Model 7550,, it is explained further up. Does yours say Model 7550?
Logged
mars
« Reply #11 on: November 18, 2009, 12:16:36 PM » |
I looked at the manual - curious since I am thinking about upgrading when I get some extra money. There is a setting to add to the cutting width under section 4.12 (page 4-29) - supposed to allow you to cut 9.5mm extra on each side - maybe that would help if what you want to do is get more width out of a 15" roll.
-mike
Logged
Speedoggy
« Reply #12 on: November 18, 2009, 12:43:24 PM » |
thanks, I didn't see that one,, I will pass that along..
Logged
mr300s
« Reply #13 on: November 18, 2009, 01:50:11 PM » |
I spoke with tech support he said DO NOT cover the sensor !!!
The way it is set up it looks like I can cut it 14" 9" which isn't bad. I am going to be buying some 24" rolls so that will fix the problem.
He said that he wouldn't recommend disabling anything, so I am good to go thanks for all the help
Logged
Graphtec CE5000-60 with Clean Cut Blades Phoenix Phire 16x20 Auto-Open Digital Heat Press Epson 1100 with Cobra CISS system SignCut, Adobe Master Collection,sign blazer & inkscape
Speedoggy
« Reply #14 on: November 18, 2009, 02:29:40 PM » |
 GREAT!!!!!!!!! thanks to all for the help....
Logged
