USCutter Vinyl Cutter and Sign Making Forum
March 19, 2010, 12:25:34 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Happy New Year - The best forum on the planet is another year older!
   Home   Help Search Login Register
Pages: [1]   Go Down
  Print
Author Topic: MH 721 running flexi, cutter gone wild!  (Read 298 times)
0 Members and 1 Guest are viewing this topic.
BigDaddyChris
Sr. Member
Offline Offline
View Profile Email
« on: November 16, 2009, 11:38:05 PM »
the file is 5.5" tall 12" wide so I oriented the file vertically, so I could get 4 stickers across and utilise my 24" stock the best.
the file says "skys off-road design" across the bottom. the first thing it tries to cut is the s, then all hell breaks loose. if I run the file horizontally, the file cuts just fine. what gives?
yesterday I was having the same issue, only less severe. I would run batches of 8 and the first s of the first sticker would be messed up, the other 7 in the run would be fine.
I tried restarting the software, the computer, the cutter shut off, and even unplugged. nothing changes this. one time it even cut the sticker 4 feet wide!
I cant attach the flexi .FS file. I could email it and see what you think. thanks in advance!
Logged
Speedoggy
Super Hero Member
Offline Offline
Skeeterlost
View Profile
« Reply #1 on: November 16, 2009, 11:45:13 PM »
have you tried going into Production Manager and erasing  what is there and changing the PACKET SIZE TO 1000 kb,  you have to actually erase it,   I run tons of very large detailed  work never a problem.  I got a member fixed last night, by doing the same thing.
Logged
Graphtec FC7000MK2-75  Flexistarter 8.5  Toshiba laptop Windows XP
YadirellT
Global Moderator
Hero Member
Offline Offline
View Profile Email
« Reply #2 on: January 06, 2010, 11:32:19 AM »
I would try what Speed says first.  If that doesn't work, try adding a new setup, and run your cut from there.  See if that works.  If not, try cutting something smaller, or a different design that you know works.  This should give you a better idea of what's causing this to happen.
Logged
jimmy1234
Sr. Member
Offline Offline
74110804 rwtech_22@yahoo.com
View Profile
« Reply #3 on: February 11, 2010, 09:29:26 AM »
This a VERY common problem with these cutters during the winter months. Static builds up on these machines because they are NOT grounded well, and you have to finish the grounding when you set it up.....dont count on the ground from the 3 prong plug as these are NOT grounded well.  There are times you have to get to the motherboard and ground that better also.
You should ground it from the cutter to the stand to external ground or its not a matter of if but when.  I have mine grounded very well even check with an ohm meter and it still died on me. The carriage that holds the blade will not move up and down. GROUND GROUND GROUND
There was a long thread on here 2 years ago about this issue and I cannot quickly find it or maybe it has been deleted, but here is a gerneral search for "grounding" on the forum:
http://forum.uscutter.com/index.php?action=search2;params=YWR2YW5jZWR8J3wwfCJ8YnJkfCd8MTksMjQsMjYsMTgsMzYsNTQsNDYsMzAsMjUsMzUsMzcsNjAsNDMsNDIsNDAsMzksMjMsMjIsNywxLDQ4LDQ3LDU1LDU2LDYxLDU3LDU4LDYyLDUwLDQ5LDYzLDY0LDYsMTAsNDEsOSwyNywyOCwzNCw4LDMzLDMyLDMxLDQ1LDQ0LDEzLDEyLDI5LDExLDUyLDUxLDE2LDE1LDE0fCJ8c2hvd19jb21wbGV0ZXwnfHwifHN1YmplY3Rfb25seXwnfHwifHNvcnR8J3xyZWxldmFuY2V8Inxzb3J0X2RpcnwnfGRlc2N8InxzZWFyY2h8J3xncm91bmRpbmc=;start=30
Good Luck,
Jim
Logged
Dakotagrafx
Super Hero Member
Offline Offline
View Profile
« Reply #4 on: February 11, 2010, 11:46:37 AM »
Not even close on this one Jimmie - read the post
Logged
Graphtec CE5000-60 , SBE, Flexi, Illustrator,  Sunie Heat Press
''Many of life's failures are people who did not realize how close they were to success when they gave up.''
-- Thomas Alva Edison
sarconastic
Super Hero Member
Offline Offline
View Profile WWW
« Reply #5 on: February 11, 2010, 02:17:01 PM »
It sounds to me like a corruption problem of some kind. Windows has been puttign out a ton of updates in the last week, and I have spent my days reinstalling software that their "FIXES" broke.
 Do you have Signblazer installed? If not download it from here and install it and see if it repeats the same problem. this eliminates the cutter out of the equation if it cuts correctly.
If it cuts correctly in Signblazer then I would try reinstalling flexi and resetting up the cutter.  It doesn't hurt to have a couple different cutters programs available and know how to use them, because in a pinch you can still create and cut.
I think it may ask if you want to save your old settings when you uninstall. say no if asked this. otherwise you may just reinstall it the same as it is now.
Kevin
Logged
"I may have said it, but you can't prove I meant it."
Laserpoint 24", FlexiSIGN PRO 8.1, SignBlazer, Inkscape, 6 in 1 Heatpress.
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
