Speedoggy
« Reply #15 on: November 15, 2009, 06:33:24 PM » |
in your default job properties, what do you have your PACKET SIZE AT? I run mine at 1000KB. and do not have any problems with detailed large graphics. I can run anything detailed and large, Most of my graphics are 10-12ft x 20" never a problem. And I just use flexistarter. Whatever you have in the Packet size, just erase and enter 1000 KB, see if that helps any. How long have you been using your Flexi?
Logged
Graphtec FC7000MK2-75 Flexistarter 8.5 Toshiba laptop Windows XP
Speedoggy
« Reply #16 on: November 15, 2009, 06:39:16 PM » |
also have you tried slowing the speed of your machine down?
Logged
ibange
« Reply #17 on: November 15, 2009, 06:55:04 PM » |
ah, yeah, my logos are only 6 inches tall for car windows...not nearly as big as what you cut. My packet size is set at 8kb. Been using flexi for a few months. Speed is the lowest it can go at 4in/s
Logged
Speedoggy
« Reply #18 on: November 15, 2009, 06:58:57 PM » |
sorry, but I am out of options for you. I would submit a ticket into USCutter.
Logged
ibange
« Reply #19 on: November 15, 2009, 07:01:08 PM » |
wow, think I found the issue. Bumped the packet size up to 1000kb and bam, everything is crisper. If this fixes it, you have my many thanks. I just hope this fixed it for good...running some tests now
Logged
Dakotagrafx
« Reply #20 on: November 15, 2009, 07:02:59 PM » |
Ohhhh Speeddoggy is good and FAST
Logged
Graphtec CE5000-60 , SBE, Flexi, Illustrator, Sunie Heat Press ''Many of life's failures are people who did not realize how close they were to success when they gave up.'' -- Thomas Alva Edison
Speedoggy
« Reply #21 on: November 15, 2009, 07:21:12 PM » |
I hope so too.
Logged
ibange
« Reply #22 on: November 15, 2009, 07:39:50 PM » |
yep, did three in a row no significant issues, very crisp. Ran out of vinyl so will have to start again tomorrow, hopefully it works for the entire order. Thanks again
Logged
Speedoggy
« Reply #23 on: November 15, 2009, 07:53:41 PM » |
not a problem  glad you got it
Logged
LeviHartzog
« Reply #24 on: November 16, 2009, 01:00:47 PM » |
Wow Speedy good job here. Way to stick with it guys.  If the problem comes back i would say the first thing to test is whether you have the issue with the pen attachment as well. To me this sounded like a blade holder that was dropped and damaged.
Logged
“Do or do not... there is no try.”
