March 18, 2010, 05:49:31 AM *
News: If you are having issues with a cutter, heat-press, printer, vinyl, and or anything else we have sold you request support. Goto http://support.uscutter.com/  and read the knowledgebase, check out the downloads, or submit a ticket for a quick resolution.
Pages: [1]   Go Down
  Print
Author Topic: mh-871, plotter??  (Read 345 times)
deth502
Hero Member
Offline Offline
View Profile
« on: November 14, 2009, 11:50:35 PM »
i was wondering, since this machine is billed as a "cutter/plotter" is htere a program i can get to communicate with it to draw out blueprints and such from cad drawings and files??
Logged
Dakotagrafx
Super Hero Member
Offline Offline
View Profile
« Reply #1 on: November 15, 2009, 03:05:43 PM »
Most of the software used with the cutters will import a DWG drawing and then use a pen attachment to plot your drawing
Logged
Graphtec CE5000-60 , SBE, Flexi, Illustrator,  Sunie Heat Press
''Many of life's failures are people who did not realize how close they were to success when they gave up.''
-- Thomas Alva Edison
deth502
Hero Member
Offline Offline
View Profile
« Reply #2 on: November 15, 2009, 04:38:26 PM »
thats what i was looking for, im using sbe to cut, i saw it can take a dxf file, which i think is one option for my cad, but most of my files are in dwg format already.
are there any alternative (free Smiley ) programs to download for me to try out?
Logged
LeviHartzog
Administrator
Super Hero Member
Offline Offline
Tech Support
View Profile WWW Email
« Reply #3 on: November 16, 2009, 01:08:54 PM »
I believe Flexi would be the best option for these files. Flexi starter is relatively low cost and works will with a lot of different file types.
SignBlazer would be a bad option for cutting cad files because SBE has not been updated for the last two years. You will spend more time trying to get the files into the software then you will doing anything else.
Logged
“Do or do not... there is no try.”
Pages: [1]   Go Up
  Print
Jump to:
