March 12, 2010, 01:24:29 AM *
News: If you are having issues with a cutter, heat-press, printer, vinyl, and or anything else we have sold you request support. Goto http://support.uscutter.com/  and read the knowledgebase, check out the downloads, or submit a ticket for a quick resolution.
Pages: [1]   Go Down
  Print
Author Topic: purchased a new (used) Printer/Cutter Need Help  (Read 219 times)
Imlost21
Sr. Member
Offline Offline
View Profile Email
« on: November 10, 2009, 06:52:43 PM »
I am having a hard time getting the images that I send to the printer to print the correct size. I send as 24 inches wide but it prints it 8 inches or so. Using signblazer till my flexi arrives, printer cutter is a Roland PC60. lol. I know it's an oldie but I am just starting out. Any assistance will be greatly appreciated.
Logged
Brandon_Davis
Administrator
Hero Member
Online Online
I LOVE TO CUT
View Profile Email
« Reply #1 on: November 10, 2009, 07:36:04 PM »
I am here for you pal... SignBlazer has some unique limitations in it's print cut ability. What you should do is first and foremost start a completely new document in SignBlazer and make sure you set it up to the right size to begin with. Then import your print, then execute the print.
Let me know if this helps, anyway I can get you to give me a call? 1-888-298-8143 X7113 ?
Logged
Brandon Davis | Support Specialist | US Cutter | 1-888-298-8143 x113 | www.uscutter.com
Imlost21
Sr. Member
Offline Offline
View Profile Email
« Reply #2 on: November 11, 2009, 07:45:30 AM »
I was wondering if the FlexiStarter will have the same problem. I am just getting used to SB. lol
Logged
YadirellT
Global Moderator
Hero Member
Offline Offline
View Profile Email
« Reply #3 on: November 12, 2009, 09:57:23 AM »
Well, you're going to have to double check the settings on all your print cuts, regardless of software.  However, you should have a bit easier time with Flexi, since it is a new program, and you'll probably be more familiar with it.  Just remember to print the image you wish to cut with the same program you are cutting from.
Logged
Pages: [1]   Go Up
  Print
Jump to:
