March 15, 2010, 06:42:06 AM *
News: Happy New Year - The best forum on the planet is another year older!
Pages: [1]   Go Down
  Print
Author Topic: Refine with no power!!!  (Read 164 times)
______
Member
Offline Offline
View Profile
« on: November 09, 2009, 10:35:54 PM »
I havent been doing a lot of cutting the last month and I keep my cutter unpluged when Im not using it, Well I just walked to get a few little things done and she will not power up at all. I used 3 outlets checked the fuse the ground and the power cable nothing is showing any signs of defect PLZ HELP
Thank you
Logged
YadirellT
Global Moderator
Hero Member
Offline Offline
View Profile Email
« Reply #1 on: November 10, 2009, 10:00:31 AM »
Have you checked your switch?  Make sure all the connections are secure?  Beyond that, I wouldn't recommend doing anything more unless you're an electrician.  If that's the case, then please go to support.uscutter.com and submit a ticket.
Logged
______
Member
Offline Offline
View Profile
« Reply #2 on: November 12, 2009, 11:55:57 PM »
I checked over everything with a DMM it was the power cable.... Couldn't tell you how that happened but in any case its all good now thanks
Logged
Pages: [1]   Go Up
  Print
Jump to:
