March 19, 2010, 05:59:31 PM *
News: If you are having issues with a cutter, heat-press, printer, vinyl, and or anything else we have sold you request support. Goto http://support.uscutter.com/  and read the knowledgebase, check out the downloads, or submit a ticket for a quick resolution.
Pages: [1]   Go Down
  Print
Author Topic: wont send to cutter  (Read 228 times)
jmoney
Hero Member
Offline Offline
View Profile Email
« on: November 08, 2009, 07:38:27 PM »
Have a mh 721 laptop died so trie installing on desktop using xp and SB through usb when I send to cutter it just goes through cut on the screen. Done a test cut on cutter and it is working fine.
Logged
HowardI
Mad Scientist of the cutter world.
Global Moderator
Hero Member
Offline Offline
View Profile WWW Email
« Reply #1 on: November 09, 2009, 11:16:51 AM »
Open signblazer.
Click the cutter button.
Click the setup button.
Please tell me the contents of the top 2 boxes.
Howard Irwin
Support Specialist
US Cutter
425-481-3555
888-298-8143
  - Option 2
Logged
It's SIGN BLAZER.  not sunblazer, sandblazer, signblaster, or anything else.
deth502
Hero Member
Offline Offline
View Profile
« Reply #2 on: November 14, 2009, 10:09:27 PM »
yup, had that quite a few times till i figured it out.
check the box as described above. make sure its set to have the cutter a the correct port you have it at.
for some reason mine seems to pick random times to switch that out on me. guessing it might have something to do with opening sb before i plug the cutter in?? but i havent narrowed down the exact reason yet.
Logged
Dakotagrafx
Super Hero Member
Online Online
View Profile
« Reply #3 on: November 15, 2009, 06:58:21 PM »
exactly - plug the cutter in them open signblazer and it should be correct each time
Logged
Graphtec CE5000-60 , SBE, Flexi, Illustrator,  Sunie Heat Press
''Many of life's failures are people who did not realize how close they were to success when they gave up.''
-- Thomas Alva Edison
HowardI
Global Moderator
Hero Member
Offline Offline
« Reply #4 on: November 16, 2009, 11:30:42 AM »
Just let us know what those settings are so we can help.
Howard Irwin
Support Specialist
US Cutter
425-481-3555
888-298-8143
  - Option 2
Logged
Pages: [1]   Go Up
  Print
Jump to:
