sjane_xoxo
« on: November 01, 2009, 06:50:36 PM » |
Hi all, if anyone can help me that would be amazing!! I just recently got a chinese Rohs cutter and after many attempts i finally got the software (artcut 5) installed as well as the driver. the only hassle is it wont seem to communicate with the computer.I have been using a usb so maybe i need to try with the serial or paralle port maybe?ive tried uninstalling and installing the software so im hoping its the cables? if anyone has any ideas so suggestions that would be great!thanks!! Sara-Jane
Logged
crshirts
« Reply #1 on: November 01, 2009, 07:27:49 PM » |
Try the serial cable and get rid of ArtCut I could never get that to import or open files. Make sure your port and machine have same settings. Carl
Logged
sjane_xoxo
« Reply #2 on: November 01, 2009, 08:26:18 PM » |
Thanks carl,ill try to locate another program and try another cable. Sara-jane
Logged
Speedoggy
« Reply #3 on: November 01, 2009, 08:31:06 PM » |
you can try Sign Blazer elements,, you can find it right here on the forum and it is a free software program to use
Logged
Graphtec FC7000MK2-75 Flexistarter 8.5 Toshiba laptop Windows XP
crshirts
« Reply #4 on: November 02, 2009, 06:07:35 PM » |
It probably has to be a null modem serial cable, all the cutters and plotters I have had use the null modem cable. I yours isn't it may not work. Last one I bought was at Staples. Carl
Logged
sjane_xoxo
« Reply #5 on: November 03, 2009, 04:11:12 AM » |
thanks everyone, I sorted it out and i am in love with my cutter!!woo hoo! i ended up installing signblaster elements and changing the ports to com2 even though im using usb and it was great!i actually resigned myself to the fact that it wouldnt work so when it did it scared the heck outta me! again many thanks! Sara-jane
Logged
gueits13
« Reply #6 on: November 11, 2009, 11:17:29 PM » |
Sara-Jane
I recently purchased the ROHS cutter and I cannot get it to work. Did you use the serial cable or usb? Any help would be appreciated, I have had the cutter for 2 weeks and am frustrated!!!!!!
Logged
LeviHartzog
« Reply #7 on: November 12, 2009, 09:51:18 AM » |
She used the USB and changed over to SignBlazer Elements which you can download from the link below. When you install your USB driver open your Device Manager (assuming you are using Windows) and expand your ports section to check which Com# to use. You can access Device Manager by click Start and either selecting run in xp or search in vista. Type devmgmt.msc and hit enter, this will open your device manager. http://support.uscutter.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=30&nav=0,4
Logged
“Do or do not... there is no try.”
gueits13
« Reply #8 on: November 12, 2009, 12:29:14 PM » |
Does it need to be a specific com#??
Logged
gueits13
« Reply #9 on: November 12, 2009, 02:58:34 PM » |
Also what driver should i install???
Logged
gueits13
« Reply #10 on: November 12, 2009, 11:42:58 PM » |
Got it to work!! WooHoo
Logged
LeviHartzog
« Reply #11 on: November 13, 2009, 10:30:09 AM » |
Logged
