March 19, 2010, 12:47:45 AM *
News: Congratulations to Mader and 2Tone for placing in USCutter's first forum contest, VectorFest 2009.
Pages: [1]   Go Down
  Print
Author Topic: CE5000-60  (Read 321 times)
Dakotagrafx
Super Hero Member
Offline Offline
View Profile
« on: October 31, 2009, 04:54:09 PM »
I haven't had time to go thru the entire 122 page manual to find it yet but If I have the advance after cut selected in flexi the cutter will feed the roll non stop on the floor.  any ideas/  got to be some setting in the cutter as I never had a problem with the Pcut, refine or copam.
i do have to admit to finally being a serial convert.  using the usb the cutter froze after about 4 feet and had to be turned off to recover . . .went serial and no more problems
Logged
Graphtec CE5000-60 , SBE, Flexi, Illustrator,  Sunie Heat Press
''Many of life's failures are people who did not realize how close they were to success when they gave up.''
-- Thomas Alva Edison
Renegade
Hero Member
Offline Offline
View Profile WWW
« Reply #1 on: October 31, 2009, 11:08:52 PM »
Probably set to sheet instead of roll 1 or roll 2
Logged
You can't fix stupid, but you can vote them out of office
Check out http://www.appareldecoratorsforum.com/
Dakotagrafx
Super Hero Member
Offline Offline
View Profile
« Reply #2 on: October 31, 2009, 11:10:25 PM »
No tried roll 1 and 2
got the cutter used so i am guessing it is a setting I have not came across yet - went to read my manual I printed and found I was short about 70 pages - so i reprinted but haven't got around to digging yet
Logged
Dakotagrafx
Super Hero Member
Offline Offline
View Profile
« Reply #3 on: November 28, 2009, 02:11:32 AM »
changed driver in flexi pro 7.6 to the 3000-60 and the problem is gone
Logged
Pages: [1]   Go Up
  Print
Jump to:
