March 19, 2010, 02:53:47 AM *
News: If you are having issues with a cutter, heat-press, printer, vinyl, and or anything else we have sold you request support. Goto http://support.uscutter.com/  and read the knowledgebase, check out the downloads, or submit a ticket for a quick resolution.
Pages: [1]   Go Down
  Print
Author Topic: Jagged lines  (Read 268 times)
lerscom
Newbie
Offline Offline
View Profile WWW
« on: October 31, 2009, 01:11:38 PM »
I'm using:
Sing Blazer Elements
Us-Cutter MH1351
I'm having this problem whit the cutter when i cut, no matter how big or small the sing is
and sometimes i doesn't finish the cut in the letters, I been trying adjusting the blade offset int SBE first .25 then .3, then 0.0, and still have the same problem, what can i do.
in the picture I'm using the pen and its the same whit the blade
Thanks
Logged
Speedoggy
Super Hero Member
Offline Offline
Skeeterlost
View Profile
« Reply #1 on: October 31, 2009, 01:17:05 PM »
if you are using the pen,  what offset are you putting it at?   Pen is 0 zero offset  as there is no blade drag.
Logged
Graphtec FC7000MK2-75  Flexistarter 8.5  Toshiba laptop Windows XP
xstreme
Sr. Member
Offline Offline
xstremedesign
View Profile WWW
« Reply #2 on: October 31, 2009, 01:25:25 PM »
I have the MH-721 and that is what mine did right be it completely went nuts. I was told by Levi at USC it was the motherboard. I replace the motherboard ($80 deposit I have not got back yet, and $40 NDA shipping) Still having the same problem, including stop cutting in the middle of a cut, strange cuts, and several other problems.  I have only had mine since Aug. of this year. Undecided
Logged
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, a lover in one hand, beer in the other, body thoroughly used up, totally worn out and screaming ~ Holy Crap!! What a ride!"
lerscom
Newbie
Offline Offline
View Profile WWW
« Reply #3 on: October 31, 2009, 04:01:57 PM »
i been testing from zero to .3 in the blade offset option and its still the same, is this normal in this plotter?
Logged
Dakotagrafx
Super Hero Member
Online Online
View Profile
« Reply #4 on: October 31, 2009, 04:43:45 PM »
check out this thread
http://forum.uscutter.com/index.php/topic,22822.315.html
Logged
Graphtec CE5000-60 , SBE, Flexi, Illustrator,  Sunie Heat Press
''Many of life's failures are people who did not realize how close they were to success when they gave up.''
-- Thomas Alva Edison
lerscom
Newbie
Offline Offline
View Profile WWW
« Reply #5 on: November 07, 2009, 01:05:14 PM »
This sucks I read all the 23 pages just to realice that the refine mh1351 its a bust and i have to upgrade to a better one
man  Cry
Logged
Scotty
Member
Offline Offline
View Profile Email
« Reply #6 on: February 15, 2010, 09:34:30 PM »
i have the same problem my cutter will not cut straight lines they are all wavy.
i have the mh871. to make things better us cutter wont reply to my email.
Logged
Pages: [1]   Go Up
  Print
Jump to:
