mr300s
« Reply #15 on: November 02, 2009, 09:35:04 PM » |
I am going to try to unistall and reinstall my original software and see what happens.
How did you make out? I thought that you had fixed the problem?
Logged
GraphTec CE5000-60 with Clean Cut Blades Phoenix Phire 16x20 Auto-Open Digital Heat Press inkscape, Signcut,Sign Blazer, Vector Magic, Adobe Master Collection And the best of all you folks at the forum !!!!
rustrocket92
Member
Offline
« Reply #16 on: November 03, 2009, 12:25:36 AM » |
I unistalled the jsi signblazer and then there wasn't a jsi machine. so I trieed the roland and nothing. I was going iinstall the original but then I found the all version so I going to try that. Cross ur fingers!
Logged
rustrocket92
Member
Offline
« Reply #17 on: November 09, 2009, 08:01:48 PM » |
I installed the all cutter version. I tried just cutting a simple shape 1" circle. Here are the results and I still having problems.
Logged
mr300s
« Reply #18 on: November 09, 2009, 08:10:26 PM » |
I installed the all cutter version. I tried just cutting a simple shape 1" circle. Here are the results and I still having problems.  What is your offset at?
Logged
rustrocket92
Member
Offline
« Reply #19 on: November 10, 2009, 01:29:46 AM » |
in the setup menu it is 0.0
Logged
rustrocket92
Member
Offline
« Reply #20 on: November 29, 2009, 12:03:17 AM » |
this thing is really pissin me off! jsi signs customer service is no help what so ever! If anyone was to ask me I would tell them to stay away from them like they were a moraly casual chick with the herp. But on another note I have a made a short video of what is going on so maybe someone else can help. Stay tuned.
Logged
mr300s
« Reply #21 on: November 29, 2009, 08:26:10 AM » |
I really don't know anything about that cutter but most call for a .25 offset even says that on the blade cases. I would start there and do test cuts increase it by five or decrease it by five until you have the results you want?
Logged
rustrocket92
Member
Offline
« Reply #22 on: November 29, 2009, 10:21:04 AM » |
what exactly does the blade offset control?
Logged
Speedoggy
« Reply #23 on: November 29, 2009, 10:30:48 AM » |
the blade drag, when it is set correctly your corners are square, and no squiggly lines when they should be straight
Logged
Graphtec FC7000MK2-75 Flexistarter 8.5 Toshiba laptop Windows XP
rustrocket92
Member
Offline
« Reply #24 on: November 29, 2009, 11:24:58 AM » |
it cuts straight lines when you can get it to cut for example if i wanted to cut shape A. my result is shape B. the thinner line is just the weed line.
Logged
rustrocket92
Member
Offline
« Reply #25 on: November 29, 2009, 11:30:34 AM » |
I am thinking it some kind of communication problem. I have cut hundreds and hundreds of difficult decals with no problems. For example I cut over 150 of these about 9" wide by 8" tall. And yes they suck to weed.
Logged
Speedoggy
« Reply #26 on: November 29, 2009, 11:37:30 AM » |
I installed the all cutter version. I tried just cutting a simple shape 1" circle. Here are the results and I still having problems.  am I looking at things wrong or something?, this test cut does not look square this is from a previous post of yours
Logged
rustrocket92
Member
Offline
« Reply #27 on: November 29, 2009, 12:56:20 PM » |
thosw were just pictures I drew to help explain what is going on. Here is a picture of the machines test cuts. I also included a picture of three letters i cut which worked fine the first time. But the second time it cut it is wrong for some reason.
Logged
