han7681
« on: October 26, 2009, 09:25:16 PM » |
HI IM CUTTING A VINYL STICKER  LIKE THE PHOTO, THE EDGE IS NOT SMOOTH, IT LIKES LIKE A GEAR. HOW CAN I SET THE CUTTER?
Logged
Booper
« Reply #1 on: October 26, 2009, 09:28:35 PM » |
what type of cutter? What software? post up the vector file so we can look at it, etc etc.......
Logged
Signmax 24", WinPCSign, CS2, BFS
han7681
« Reply #2 on: October 26, 2009, 09:42:58 PM » |
im using us fine cutter and sign cut and art cut.
both soft ware are same. looks like the photo.
head.ai (174.82 KB - downloaded 24 times.)
Logged
Dakotagrafx
« Reply #4 on: October 26, 2009, 10:02:56 PM » |
Thats about the third one to have that problem
Logged
Graphtec CE5000-60 , SBE, Flexi, Illustrator, Sunie Heat Press ''Many of life's failures are people who did not realize how close they were to success when they gave up.'' -- Thomas Alva Edison
Booper
« Reply #5 on: October 26, 2009, 10:10:11 PM » |
I just looked at your file hoping you had too many construction points but you dont, its smooth. You have a cutter issue. I'll cut it and take a pic of it for you hang on. Is the photo you took of the right hand side of what looks like the brim of a hat???
Logged
Booper
« Reply #6 on: October 26, 2009, 10:24:17 PM » |
I just cut it, I did it at the size you posted, like 4 inches tall.  Ben
Logged
han7681
« Reply #7 on: October 27, 2009, 03:39:54 PM » |
dear ben thanks for that!! if the file is not a problems, what is the problem with the cutter? i thought it might be too many construction point. i just bought the cutter a week ago. everything is new.. that was my first cutting very disappointed with the first cutting,,,
« Last Edit: October 27, 2009, 03:49:51 PM by han7681 »
Logged
Booper
« Reply #8 on: October 27, 2009, 05:20:46 PM » |
Well if thats the first thing you've cut I would say you need to spend some time getting to learn the pressure, speed, and blade offsets and height of it. Spend a good couple hours and a few feet of vinyl and do lots of test cuts at different settings to see if they make any difference, worse or otherwise. If after all that your still having the exact same problem then it might be something wrong with the machine, but I think you should be able to get it dialed in. There's a TONNE of good info in the "Instructional Contributions" section, do some reading in there and you'll get alot of info on how to get it running smoother.
Ben
Logged
gadget1961
Member
Offline
« Reply #9 on: October 29, 2009, 07:53:22 AM » |
i was wondering if any one has settings on pressure for any machine at different vinyls , such as glitter and the more expensive to the cheaper types just curious thanks
Logged
JUST BE CALM AND WEED ME
