USCutter Vinyl Cutter and Sign Making Forum
March 15, 2010, 12:16:59 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: If you are having issues with a cutter, heat-press, printer, vinyl, and or anything else we have sold you request support. Goto http://support.uscutter.com/  and read the knowledgebase, check out the downloads, or submit a ticket for a quick resolution.
   Home   Help Search Login Register
Pages: [1]   Go Down
  Print
Author Topic: Random cuts while cutting.  (Read 310 times)
0 Members and 1 Guest are viewing this topic.
SSW
Hero Member
Offline Offline
View Profile Email
« on: October 06, 2009, 07:42:31 AM »
I was cuting out some things last night and while weeding them I noticed that there was random cuts in the letters.  Huh?
Anyone know what causes this?
Logged
sarconastic
Super Hero Member
Offline Offline
View Profile WWW
« Reply #1 on: October 06, 2009, 09:08:42 AM »
Very rarely are there any RANDOM cuts on a cutter, unless there is a machine problem. Most of the time the random cuts are either where the letters overlap, and in that case you select all the letters and weld them together prior to cutting. Or you have some wild nodes somewhere on the vector image.
Go into your design program and using the node editor, do a CTL + A. This will select all of the image, then you can see any errant nodes and delete them.
Kevin
Logged
"I may have said it, but you can't prove I meant it."
Laserpoint 24", FlexiSIGN PRO 8.1, SignBlazer, Inkscape, 6 in 1 Heatpress.
SSW
Hero Member
Offline Offline
View Profile Email
« Reply #2 on: October 06, 2009, 09:22:51 AM »
Thanks!
I'll try it out and let you know.
Logged
dragonshack
Newbie
Offline Offline
View Profile Email
« Reply #3 on: October 22, 2009, 03:03:22 PM »
I have a problem with "random cuts" as well.  I am using Flexi 8 and a pcut 630. For some reason it will cut a diagonal line across the vinyl, nothing to be cut there... It does this on just about every job that I cut.  Any suggestions?  Thanks for any and all help.
Logged
modeltee
Newbie
Offline Offline
View Profile Email
« Reply #4 on: November 03, 2009, 06:08:39 PM »
Oh yes! This is EXACTLY the problem we are having. Our current cutter (who may soon get replaced!) is a Master Cutter by Desay. We are running SmartCut Pro with Windows Vista. When running a long job (today's project was 6' long) it will randomly put MANY diagonal lines in every direction across the vinyl. I bet the last piece I tried to cut today put about 20 various diagonal lines across it for no good reason.
If anyone can help us with this problem I would greatly appreciate it!
Stacy
Logged
JoeBlow
Super Hero Member
Offline Offline
View Profile
« Reply #5 on: November 03, 2009, 06:30:40 PM »
There are a few reasons for random or stray cuts.  If the plotter has been cutting other graphics OK and suddenly stray cuts, I would first check for an "Open Path" in your current graphic.  If there's definitely no open paths, then static build up maybe the cause, and you possibly need too earth the plotter.
USB connections can also cause stray cuts and erratic behaviour on plotters, try unplugging and re plugging your USB cable.  Check too see that USB is a nice firm connection, a "Parallel Port" connection is a more reliable and stable connection.
Memory on very large graphics or long runs, sometimes can also be a problem.
Joe
« Last Edit: November 03, 2009, 06:34:02 PM by JoeBlow » Logged
Roland CAMM-1 PNC-1000 * Roland CAMM-1 PNC-1100 * PC * XP Pro * CorelDRAW X3 * VinylMaster Pro 2.5 * FlexiEXPRESS * Inkscape
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
