March 17, 2010, 11:08:24 PM *
News: Happy New Year - The best forum on the planet is another year older!
Pages: [1]   Go Down
  Print
Author Topic: My cutter is cutting jagged. Anyone please help!  (Read 438 times)
wroebuck34
Newbie
Offline Offline
View Profile
« on: September 09, 2009, 03:44:46 PM »
Crap, I hate to double post, but I noticed this forum after I put this up in the general discussion. This is where this belongs.
I have a Lynx 60 vinyl cutter I bought from Sign Warehouse a while back.
So here is my problem. Anytime I cut vinyl, the cutter will make a wierd sound at start up. When it goes to cut right to left or left to right, it cuts a jagged line. When it is doing this, I can see the roller that feeds the vinyl jitter back and forth. Here is a list of tests I have done:
I have replaced the blade, teflon strip, the blade carriage, & a new cable. A year ago I replaced the y motor.
Yes the blade is set the correct depth & offset.
Yes the carriage is on correctly & in the track.
Yes slowing down the cut speed from default 30 cm/s to 3cm/s helps but does not resolve the issue.
I do not believe it is a communication issue because it will do this on a test cut.
I do not believe it is the blade holder because I swapped a pen into the carriage & it still does the jagged movement.
I have posted a video on youtube:
<a href="http://www.youtube.com/v/-JTOUWejans" target="_blank">http://www.youtube.com/v/-JTOUWejans</a>
Thank you to anyone that can help. This has been on goiung for the last month & I am losing out daily.
« Last Edit: September 09, 2009, 04:43:12 PM by wroebuck34 » Logged
cutme
Global Moderator
Super Hero Member
Offline Offline
View Profile WWW Email
« Reply #1 on: September 09, 2009, 06:03:30 PM »
maybe its the main board.
bb
Logged
(\__/)
(")_(")
laserpoint24, epson wf1100
Women and cats will do as they please, and men and dogs should relax and get used to the idea.
                        Robert A. Heinlein
"Show me a sane man and I will cure him for you. " - Carl Gustav Jung (1875-1961)
HowardI
Mad Scientist of the cutter world.
Global Moderator
Hero Member
Offline Offline
« Reply #2 on: September 28, 2009, 09:28:55 AM »
Watching this video and seeing the edge of the cut I think it's either the encoder, the motor, or motherboard.  Most likely encoder or motor.
It's possbile that the encoder is actually part of the motor.  if the machine is on and idling, can you rock the feed roller back and forth or is it firmly held in place?
Logged
It's SIGN BLAZER.  not sunblazer, sandblazer, signblaster, or anything else.
wroebuck34
Newbie
Offline Offline
View Profile
« Reply #3 on: September 30, 2009, 03:09:25 PM »
I replaced the x-motor & it resolved this issue.
Logged
Brandon_Davis
Administrator
Hero Member
Offline Offline
I LOVE TO CUT
View Profile Email
« Reply #4 on: October 08, 2009, 08:04:28 PM »
wroebuck how much did you pay for the motor?
Logged
Brandon Davis | Support Specialist | US Cutter | 1-888-298-8143 x113 | www.uscutter.com
MaderDesign
Super Hero Member
Offline Offline
Drew+Duece+2
« Reply #5 on: October 10, 2009, 11:00:46 PM »
My machine is doing the same thing, only it's brand new and DOA, we've done everything we could to fix this thing. Brandon I'll give you a call on Monday to get this thing switched out.
Logged
Copam CP-2500
27" iMac Core i7
Mac Pro - 8 Core (Two - 2.26ghz Quad Core Xeon)
Photoshop CS4
Illustrator CS4
FlexiSign Pro 8.6
Wacom Intuos3 6x11
Pages: [1]   Go Up
  Print
Jump to:
