March 19, 2010, 04:12:50 PM *
News: Happy New Year - The best forum on the planet is another year older!
Pages: [1]   Go Down
  Print
Author Topic: Snow Leopard and SignCut  (Read 621 times)
space design
Hero Member
Offline Offline
tenofive
View Profile WWW
« on: September 08, 2009, 09:49:21 PM »
Anyone upgraded to 10.6 yet? I am worried that SignCut won't work if I do.
Logged
Laserpoint 24 | iMac - Snow Leopard | Adobe CS3 | SignCut Productivity Pro
727pilot
Newbie
Offline Offline
View Profile Email
« Reply #1 on: September 10, 2009, 04:47:10 PM »
Upgraded this morning and, of course, got an emergency call for a sign about an hour later.
Well signcut works just fine.  No Problems at all.
On the other hand Inkscape does not.  I crashes as soon as it tries to open.
Logged
Mac Pro 8 core
Illustrator CS4
Signcut Productivity Pro
US Cutter MH 741
Keyspan adapter
VendettaVinyl
Hero Member
Offline Offline
View Profile WWW Email
« Reply #2 on: September 11, 2009, 09:20:08 AM »
Also CS4 is not 100% with 10.6 yet. Apple is still working on it
Logged
MH Refine871
Sign Cut Pro on Macbook
Illy CS3
space design
Hero Member
Offline Offline
tenofive
View Profile WWW
« Reply #3 on: September 11, 2009, 01:41:29 PM »
Good to know! I am on CS3 - I hear there are a few issues, but for the most part it works fine. I guess that I will upgrade!
Logged
Daddy-o
Member
Offline Offline
View Profile Email
« Reply #4 on: September 11, 2009, 09:28:39 PM »
I haven't run into any problems yet with CS3,
Snow Leopard does seem to be noticeably faster though. Glad I made the switch.
Daddy-o
Logged
Kimon
Hero Member
Offline Offline
View Profile Email
« Reply #5 on: September 14, 2009, 03:41:11 PM »
We have found several users who have communication trouble with Summa cutters, possibly the drivers are not compliant for the Summa Usb connection. We have however tested Snow Leopard with 20 or so standard import machines and have had great success so far.
SHould you encounter snow leopard problems we would love to try and assist you so please let us know at support@sc-x2.com One other thing we have not released a Snow Leopard certified version of signcut so upgrading now could be problematic, we suggest possibly testing on a secondary machine before making your business dependent on a freshly released and unproven OS.
Logged
BannerJohn
Global Moderator
Super Hero Member
Offline Offline
View Profile
« Reply #6 on: September 14, 2009, 03:57:44 PM »
keep an eye on the Inkscape site...it is open source and there are people always working to improve it.
Logged
Sign Maker.
Drummer
Malcontent
Agitator
Daddy-o
Member
Offline Offline
View Profile Email
« Reply #7 on: September 14, 2009, 06:27:41 PM »
Daddy-o
Was afraid I might have to recant my recommendation after this weekend. I use an open source java-based program to run model trains called JMRI. After struggling to solve a communication issue, I found the following on the JMRI site:
"If you're using Mac OS X 10.6 (Snow Leopard), you first have to configure Java on Mac OS X for "32 bit" operation. Mac OS X 10.6 can run in either 32-bit or 64-bit mode, but the communications libraries we currently use are only available in 32-bit mode. To do this, open the "Java Preferences" application from the Utilities folder inside the computer's Applications folder, then set the default "Java Application" in the lower window to "Java SE 6 32-bit"."
An easy fix once you know about it, but quite worrisome until you do. Not sure if it will address anyone's issues here, but figured it can't hurt to spread the word.
Daddy-o
Logged
space design
Hero Member
Offline Offline
tenofive
View Profile WWW
« Reply #8 on: September 14, 2009, 06:31:37 PM »
I upgraded to Snow Leopard today. I just gave the vinyl cutter a trial run. SignCut crashed a few times, but then gave me a warning about switching licenses to a new computer. It finally cut a few minutes later.
Logged
Kimon
Hero Member
Offline Offline
View Profile Email
« Reply #9 on: September 14, 2009, 08:00:12 PM »
Not sure about the crashes but a new operating system creates new hardware ID's which is seen as a new computer by our server which will create a transfer. We allow users 5 transfers to allow for hardware or os upgrades. Should you continue to have trouble please let us know at support@sc-x2.com
Logged
space design
Hero Member
Offline Offline
tenofive
View Profile WWW
« Reply #10 on: September 15, 2009, 09:29:08 AM »
Worked fine after the initial hick-ups. Thanks for your support. I will let you know if I run into any issues.
Logged
space design
Hero Member
Offline Offline
tenofive
View Profile WWW
« Reply #11 on: September 25, 2009, 08:21:08 AM »
Worked with SignCut again last night...It crashed a total of 23 times before it would stay running long enough to make a cut. It just shuts down. My persistence pays off, though, cause it will eventually run. Just frustrating. I knew it was a risk in the upgrade to 10.6.
Logged
Kimon
Hero Member
Offline Offline
View Profile Email
« Reply #12 on: September 30, 2009, 12:43:18 AM »
New revision for Mac Snow Leopard please try and let us know how it works for you.
http://www.signcutpro.com/Customer-Login.html once logged in click downloads and install directly over the old installation.
Logged
Pages: [1]   Go Up
  Print
Jump to:
