March 13, 2010, 06:27:02 AM *
News: Congratulations to Mader and 2Tone for placing in USCutter's first forum contest, VectorFest 2009.
Pages: [1]   Go Down
  Print
Author Topic: NEEDING HELP LINING UP 15 INCH VINYL  (Read 460 times)
Photoman
Member
Offline Offline
View Profile Email
« on: August 31, 2009, 06:46:27 PM »
HEY, Im trying to set up to cut some 15 inch vinly and when i adjust my rollers it says in need to rellign my rollers, I have a graphtec ce5000-60 and cant seem to figure this out . any help will be welcomed...Thanks Kenny
Logged
Speedoggy
Super Hero Member
Online Online
Skeeterlost
View Profile
« Reply #1 on: August 31, 2009, 06:54:21 PM »
Well,  You obviously do not have the rollers right over the  grit rollers,,  You have to have 1 roller on the longer area, and the other roller right over the next grit roller, for 15"  OR Like I do  I shut it off,,   I never use it,   mine is> click  Menu > NEXT  button 3 times,  then background setting> click  next tru to pinch roller sensor> disable> ENTER  hope that helps
I also don't use the media sensor,  where it measures the width of the vinyl everytime,   In the same background settings , where it says media sensor,  I also disable that,  It wastes alot of vinyl doing that,,  I put the carriage head where I want it to be, then hit origin,
« Last Edit: August 31, 2009, 07:01:43 PM by Speedoggy » Logged
Graphtec FC7000MK2-75  Flexistarter 8.5  Toshiba laptop Windows XP
Photoman
Member
Offline Offline
View Profile Email
« Reply #2 on: August 31, 2009, 07:09:47 PM »
THANK YOU SO MUCH MOVING TO THE GRIT ROLLERS SOLVERED THE PROBLEM WORKING GREAT NOW ...THANKS SOOO MUCH IM A NEWBIE HERE .......KENNY
Logged
Speedoggy
Super Hero Member
Online Online
Skeeterlost
View Profile
« Reply #3 on: August 31, 2009, 07:10:48 PM »
glad I could help Thumbsup
Logged
Photoman
Member
Offline Offline
View Profile Email
« Reply #4 on: August 31, 2009, 07:18:13 PM »
HEY HAVE YOU EVER CUT ANY EASYWEED BY SASSER I HAVE SOME TO CUT AN DWAS WANTING TO ADJUST MY FORCE AND DONT KNOW HOW DO YOU HAVE ANY IDEAL IF IT CUTS DIFFERENT THAN REG VINYL...kENNY
Logged
Speedoggy
Super Hero Member
Online Online
Skeeterlost
View Profile
« Reply #5 on: August 31, 2009, 07:43:41 PM »
No Kenny, I never have,, I have never messed with it.  is it thicker ?  If so, you will need more force...  you can run a test  square/triangle on it  or just do a small decal,  and see how it does,,   best option I know of.
Logged
Photoman
Member
Offline Offline
View Profile Email
« Reply #6 on: August 31, 2009, 09:23:36 PM »
ok thanks so much again...Have a great evening...Kenny
Logged
Pages: [1]   Go Up
  Print
Jump to:
