USCutter Vinyl Cutter and Sign Making Forum
March 19, 2010, 10:44:21 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Congratulations to Mader and 2Tone for placing in USCutter's first forum contest, VectorFest 2009.
   Home   Help Search Login Register
Pages: [1]   Go Down
  Print
Author Topic: Cutting Curved Text with Illustrator/Graphtec CE5000  (Read 339 times)
0 Members and 1 Guest are viewing this topic.
ddakin
Newbie
Offline Offline
View Profile Email
« on: August 11, 2009, 07:41:37 AM »
Hi guys. I'm in a jam here. I have a section of curved text I need to cut. I typed the text in an illustrator text box and then used the arc tool to curve it. Unfortuantely when I send it to cut, Cutting Master only sees it as a straight line of text.
HELP PLEASE! I need to cut this right away.
Any help would be great. Thanks
Dan
Logged
Speedoggy
Super Hero Member
Online Online
Skeeterlost
View Profile
« Reply #1 on: August 11, 2009, 08:16:35 AM »
Dan
maybe try   SAVE AS> and then import the design into  your cutting software.  Just a thought.
« Last Edit: August 11, 2009, 08:51:29 AM by Speedoggy » Logged
Graphtec FC7000MK2-75  Flexistarter 8.5  Toshiba laptop Windows XP
Renegade
Hero Member
Offline Offline
View Profile WWW
« Reply #2 on: August 12, 2009, 10:53:49 PM »
Have you converted it to curves, welded it, & looked at it in wireframe view?
Logged
You can't fix stupid, but you can vote them out of office
Check out http://www.appareldecoratorsforum.com/
joelmarley
Sr. Member
Offline Offline
View Profile Email
« Reply #3 on: August 13, 2009, 03:34:18 PM »
Select your text, then select objects, then select expand. This will turn it into a path. Then it should cut.
Joel
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
