USCutter Vinyl Cutter and Sign Making Forum
July 30, 2010, 02:14:40 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: If you are having issues with a cutter, heat-press, printer, and or vinyl goto http://support.uscutter.com/  and read the knowledgebase, check out the downloads, or submit a ticket for a quick resolution.
   Home   Help Search Login Register
Pages: [1]   Go Down
  Print
Author Topic: Double layer flex possible?  (Read 301 times)
0 Members and 1 Guest are viewing this topic.
CRD
Super Hero Member
Offline Offline
View Profile WWW Email
« on: July 10, 2009, 10:49:36 AM »
Hi,
Just for the fun of my web page www.customracingdecal.com I need to make three or four tshirts using flex.
A friend has a heat press but no time to design and cut and not the knowledge what I want.
I can do laser or injet transfer print and contour cut but I like to have it with flex only to get longer lasting results.
Now if you see the t-shirt with logos is this possible?
How do you layer flex material and put it on the tshirt before pressing?
If I have to buy more then flex only I skip and let some one else let them do.
But I thought I try do it myselve first.  Grin
Paco
Logged
Never too old to learn and I learn every day. ;-)
I have moved with others to http://www.vinylforum.org
For more info join me there and also new versions of the newbie manual.
Thanks Paco
99v8miata
Super Hero Member
Offline Offline
« Reply #1 on: July 10, 2009, 01:11:56 PM »
You would layer it like a decal and press the first color for about 5 seconds then the second color for about 5 seconds and then the last color fro the time that is recommended.
Dave
Logged
CRD
Super Hero Member
Offline Offline
« Reply #2 on: July 10, 2009, 02:34:31 PM »
That I understand but do I need special transfer tape?
I only have paper transfer tape I use for normal vinyl.
Paco
Logged
Thanks Paco
sciondrgn
Guest
« Reply #3 on: July 10, 2009, 03:59:06 PM »
Im not sure what flex is?
but on normal heat press vinyl you dont use a transfer tape because the back is already on there.. You cut the image in reverse which leaves the backing on top when you press down.
Logged
CRD
Super Hero Member
Offline Offline
« Reply #4 on: July 10, 2009, 04:10:38 PM »
Dragon,
Flex I mean is just like sisser weed or something.
If you cant look through how do you align two layers or are carriers for this stuff always transparant?
Paco
Logged
Thanks Paco
sciondrgn
Guest
« Reply #5 on: July 10, 2009, 07:17:00 PM »
Dragon,
Paco
ohh durr Thermoflex hehe,
So far everything ive used the carriers have been transparent.. , I have some EasyWeed and mainly stick to Spectra Eco Film..
Spectra Cut II had a semi transparent (think frosted glass) and everything else has been totally see through
Logged
CRD
Super Hero Member
Offline Offline
« Reply #6 on: July 11, 2009, 01:16:23 AM »
VD,
"Clear" enough. Grin
I go order some Thermoflex
Thanks
Logged
Thanks Paco
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
