I do not know anything about Signblazer,,,, but in Flexi,,,,, You can place tile marks, it does NOT cut across your design, it only cuts everything up to the point, then advances, cuts up to that point, then advances until it is at the end of the design,You still have only I big stripe. Not sections. That way you do not have your cutter going from one end of the vinyl ,clear to the other end and back and forth. I make stripes all the time for my business, this is how I do it and they are perfect. In the picture I have put 6 tiles in your design, each at about 14.2" So it will cut all of the first 14".2" then advance to the next 14.2" then advance to the next 14.2" until it gets to the end of the design... It does not cut the lines ACROSS the design,,,,
I set up flexi this way to cut a 6"x 48" decal. Just to see how it worked, well it cut a line through the decal at the point where the tiles meet, not the entire sheet just the decal part. I am using flexi pro 8.1. We use this for our color plotting so I figured I would use it for cutting also. Is there something that I should be looking for to stop it from cutting the tile lines?
