March 18, 2010, 03:38:15 AM *
News: If you are having issues with a cutter, heat-press, printer, vinyl, and or anything else we have sold you request support. Goto http://support.uscutter.com/  and read the knowledgebase, check out the downloads, or submit a ticket for a quick resolution.
Pages: [1] 2   Go Down
  Print
Author Topic: What is the standard size print for the front & back of a tshirt?  (Read 1835 times)
Jenl93
Global Moderator
Super Hero Member
Offline Offline
Proud owner of the Copam 2500
View Profile
« on: May 16, 2009, 12:32:00 PM »
Since I went through this entire area, I didn't see where the standard sizes are.
When a customer wants the front of a shirt done, what is the standard size print? Not talking pocket print (I know that one)
Also what is the size for the back?
Thanks.
I know I have the info somewhere, but don't know where I put it after the move!  Lips Sealed
Logged
May you have a blessed 2010!
Primal Rage Outdoors
Hero Member
Offline Offline
Pcut 24"-Flexi 8.1 & Photoshop-Illustrator CS4
educated_rage
View Profile WWW Email
« Reply #1 on: May 16, 2009, 03:50:32 PM »
Jenn,
  I have been using a standard 8" wide by 10" height format, and try to fit my fonts and graphics into that area, thats on large and xl shirts, you can inch upward or backward from there. don't be afraid to experiment.
Logged
Pain is the Prize... The Tattoos & Piercings are just Souvenirs !
SayIt!
Sr. Member
Offline Offline
View Profile
« Reply #2 on: May 16, 2009, 08:07:18 PM »
Hi Jenn,
I agree with Primal about experimenting but there are some "industry specs" :
Left Chest = 4"
Full Front / Full Back = 12"
Short Sleeve = 4"
Long Sleeve = 12"
Leg = 14"
Sometimes 12" wide is too big for the front...I have actually had customers request 10" wide.
Hope that helps!
Chrissy
Say It!
Logged
Renegade
Hero Member
Offline Offline
View Profile WWW
« Reply #3 on: May 16, 2009, 09:53:21 PM »
Generally standard transfers are normally a max size of 12"x12" (slightly less actually), but I'd say a 10" width is more of the standard and the height is pretty variable, but I'd say normally approximately 6-8" tall is common.
Logged
You can't fix stupid, but you can vote them out of office
Check out http://www.appareldecoratorsforum.com/
Jenl93
Global Moderator
Super Hero Member
Offline Offline
View Profile
« Reply #4 on: May 17, 2009, 06:19:45 AM »
Thanks to all three of you....I truely appreciate it and this will come in handy!
Logged
rayray1039
Newbie
Offline Offline
View Profile Email
« Reply #5 on: May 22, 2009, 01:16:09 AM »
Great info, everyone!
Is there a standard on how to position the graphics on the shirts as well?   I would guess full fronts and backs would center horizontally, but how far up/down?
How about locations for small logos on the right sides of shirts?
Thanks!
-Ray
Logged
Jenl93
Global Moderator
Super Hero Member
Offline Offline
View Profile
« Reply #6 on: May 22, 2009, 01:53:18 PM »
I had found this cheat sheet, hope it helps.
Logged
Renegade
Hero Member
Offline Offline
View Profile WWW
« Reply #7 on: May 22, 2009, 04:54:55 PM »
Cool!  I like that.  Any chance you got it from somewhere in a pdf format that you can link us too?  Just want to put it up in the shop for reference and am too lazy to retype it.  Thumbsup
Logged
CherokeeDesign
Hero Member
Offline Offline
View Profile WWW
« Reply #8 on: May 22, 2009, 05:22:25 PM »
There is a faint "inkjetgarmentprinters.com" watermark...I'd love to have a copy of it too, but can't find it on that site yet.
« Last Edit: May 22, 2009, 05:35:01 PM by CherokeeDesign » Logged
Jenl93
Global Moderator
Super Hero Member
Offline Offline
View Profile
« Reply #9 on: May 22, 2009, 05:32:00 PM »
Try this site,  it has a pdf of another version
http://www.screenprintinguniversity.com/forums/viewtopic.php?f=52&t=3921&sid=18592161f3f979707bdd57daad8b35dd
Logged
CherokeeDesign
Hero Member
Offline Offline
View Profile WWW
« Reply #10 on: May 22, 2009, 05:35:45 PM »
awesome, thank you!
Logged
Jenl93
Global Moderator
Super Hero Member
Offline Offline
View Profile
« Reply #11 on: May 22, 2009, 05:39:11 PM »
no problem
Logged
rayray1039
Newbie
Offline Offline
View Profile Email
« Reply #12 on: May 22, 2009, 09:03:50 PM »
Thanks everyone, these cheat sheets are awesome!
Logged
russdabuss
Member
Offline Offline
View Profile Email
« Reply #13 on: May 29, 2009, 11:50:12 AM »
Wow- Unfortunately, I don't get on here much but THANKS for this information everyone!!
Logged
Cap
Member
Offline Offline
View Profile Email
« Reply #14 on: June 09, 2009, 08:22:57 PM »
You can use a ruler to measure and spend the extra time for each shirt if it suits you. General rule of thumb for a full front print is 3 fingers down from the bottom of the collar. Your best bet is find what is right for you and your shop and you must have your screen room on the ball. All artwork should be burned in the same spot every time ie... top of image is 6" down from the bottom of the screen frame. This way when you load your shirts in the same spot all the time then its always right on. Speed is the key and pre press is always where the most time can be saved.
Logged
Pages: [1] 2   Go Up
  Print
Jump to:
