USCutter Vinyl Cutter and Sign Making Forum
March 16, 2010, 05:37:45 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Congratulations to Mader and 2Tone for placing in USCutter's first forum contest, VectorFest 2009.
   Home   Help Search Login Register
Pages: 1 [2] 3 4   Go Down
  Print
Author Topic: MANUAL FOR NEW BIE - HOW TO START FROM NOTHING TO YOUR FIRST CUT!  (Read 5691 times)
0 Members and 1 Guest are viewing this topic.
CRD
Super Hero Member
Offline Offline
View Profile WWW Email
« Reply #15 on: July 06, 2009, 01:53:52 PM »
Version 4.3 is ready.
I added a tip/part for those suffering with USB problems in chapter 6.
Thanks for vinyl dragon to provide it.
Paco
Logged
Never to old to learn and I learn every day. ;-)
PCUT LASERPOINT 24", SIGNCUT PRODUCTIVITY, CORELX4, ILLUSTRATOR CS3. Not enough time...........
www.customracingdecal.com
mcpcola
Newbie
Offline Offline
View Profile Email
« Reply #16 on: July 07, 2009, 09:41:21 PM »
Linky no work for me Huh?
Logged
CRD
Super Hero Member
Offline Offline
« Reply #17 on: July 08, 2009, 12:35:41 AM »
Works again.
Sorry for inconvenience,
paco
Logged
Razpewton
Member
Offline Offline
View Profile Email
« Reply #18 on: July 28, 2009, 07:40:34 AM »
Thanks for the manual. Awesome contribution to the community.  Thumbsup Thumbsup
Logged
CRD
Super Hero Member
Offline Offline
« Reply #19 on: August 27, 2009, 02:53:29 PM »
Version 4.4 is online.
Paco
Logged
lueman
Hero Member
Offline Offline
View Profile
« Reply #20 on: September 16, 2009, 07:31:17 PM »
Great job Paco Thank you.
Logged
CRD
Super Hero Member
Offline Offline
« Reply #21 on: October 06, 2009, 03:46:16 PM »
Version 4.5 is online.
More about the RED kill switches.
FAQ at the end of the manual
USB port setting in SBE.
Have fun with it.
Paco
Logged
han7681
Member
Offline Offline
View Profile Email
« Reply #22 on: October 27, 2009, 10:50:44 PM »
hi
thanks for ur instructions
i have got few things not to understand.
all u mean in blade depth is like the photo i attached?
or is there another setting i need to do?
and
when you place blade carriage into carriage arm, how much gap do i leave between blade and bottom?
blade need to touch the bottom or slightly up from the bottom ? ( vinyl thickness)
thanks
Logged
Speedoggy
Super Hero Member
Online Online
Skeeterlost
View Profile
« Reply #23 on: October 27, 2009, 11:28:44 PM »
hi
and
thanks
blade and bottom of what?,  you put the blade holder in it's hole on the carriage arm.  and tighten it down, that is it..  you do not adjust the bladeholder.
Logged
Graphtec FC7000MK2-75  Flexistarter 8.5  Toshiba laptop Windows XP
CRD
Super Hero Member
Offline Offline
« Reply #24 on: October 28, 2009, 02:00:09 AM »
The blade holder has a ring around the middle.
Slide the blade holder into thecarriage arm until it hits the ring and thighten the screw to hold it.
The knife sticking put the blade holder is correct for half credit card thickness.
Paco
Logged
han7681
Member
Offline Offline
View Profile Email
« Reply #25 on: October 28, 2009, 07:43:50 AM »
thanks for replying
im setting a force and speed.
when i set v: 60-70 F: 30, it seems ok for cutting a nomal vinyl
but the manual says it normally v :60, F : 100-150
wonder my setting is not correct?
thanks
« Last Edit: October 28, 2009, 01:21:17 PM by han7681 » Logged
CRD
Super Hero Member
Offline Offline
« Reply #26 on: October 28, 2009, 03:33:08 PM »
Take the knife holder out the carriage arm.
Run the holder over the vinyl you like to cut.
If it cuts through the backing reduce knife sticking out.
Repeat until it cuts the vinyl but not the backing.
Remount the blade holder.
Test from 30 pressure onwards until it cuts nicely leave speed at 60 and test with a 3 x 3 cm square.
Paco
Logged
woodchip
Newbie
Offline Offline
View Profile Email
« Reply #27 on: November 07, 2009, 09:06:25 AM »
Hi, Thank you for this manual, it has helped so much
I am having problems with the USB driver.
I downloaded the file you had on the manual and extracted it.
When I go to my device manager, the USB to Serial port is listed under other devices and it is highlighted yellow.When I double click it it says that it is not configuered correctly, so I pressed reinstall driver  It then tells me that it can not install hardware.
I tried to set up the USB cable but can not figure out the com port that is being used, I tried a few of them, but it does not hook up to the plotter.
Your help is greatly appreciated.
Diane
Logged
CRD
Super Hero Member
Offline Offline
« Reply #28 on: November 07, 2009, 02:07:32 PM »
OK here we go and I hope this helps.
Follow the steps exactly (do not alter it) please!!!!!!!!! Grin
Remove all the serial to USB drivers ports you see in the hardware manager.
Then remove all external USB devices and cables connected included the plotter to the PC (except the mouse and keyboard if they are USB).
Restart the PC.
Perform the FTID.exe file for the USB drivers you downloaded.
Now hook the USB from the plotter to the PC and it should mention it has found new hardware and installs the driver automaticly. If not let me know.
Then go to the device manager and check which serial USB comport is used.
Select this port in your software to be the same as mentioned in the manual.
If this does not work you might choose a recovery point in Windows (Vista or XP).
Choose a point before the plotter driver or any other plotter driver was installed.
Remember that some software installed will be deleted and need to be reinstalled again (NO WARRANTY).
Now install the FTDI.exe file again and hook de plotter on and see if it detecs new hardware and installs the USB drives.
Let us know,
Paco
Logged
CRD
Super Hero Member
Offline Offline
« Reply #29 on: November 26, 2009, 01:47:42 AM »
We are currently at version 4.6
We added the red kill switch as reset button option for the US CUTTER LASERPOINT machines.
Regards and enjoy,
Paco
Logged
Pages: 1 [2] 3 4   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
