USCutter Vinyl Cutter and Sign Making Forum
March 09, 2010, 06:30:11 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Congratulations to Mader and 2Tone for placing in USCutter's first forum contest, VectorFest 2009.
   Home   Help Search Login Register
Pages: [1]   Go Down
  Print
Author Topic: Graphtec not cutting all the way to edge  (Read 492 times)
0 Members and 1 Guest are viewing this topic.
fluffer
Newbie
Offline Offline
View Profile
« on: April 16, 2009, 03:16:27 PM »
Just got my new Graphtec, so far I love it.  One problem I have is that when I do large cuts, the edge of the left side never gets cut, it just acts like the rest of what it is suppose to cut is not there, almost like some kind of margin issue...Anybody have any tips?
Logged
Renegade
Hero Member
Offline Offline
View Profile WWW
« Reply #1 on: April 17, 2009, 09:11:59 AM »
I've had that when I get my graphic a little to big for the actual cuttable width, but normally I know that has happened when I look at the weed lines and such on the screen or when I get the edge of the cuts that should have been there farther up the material.  Best thing is to use the poll size button and then you can compare your image size to your cuttable width and make sure its slightly less.
Logged
You can't fix stupid, but you can vote them out of office
Check out http://www.appareldecoratorsforum.com/
frontierjoe
Member
Offline Offline
View Profile WWW Email
« Reply #2 on: July 31, 2009, 09:14:57 PM »
If your using signblazer in your cutter interface ( where you select and apply cut) in setting change the width of your vinyl to 24 or 30 or whatever your cutting so that it knows how wide the vinyl is. Length doesn't matter unless its setup at like 48 inchs, i just set lenght to like 10 ft.
Logged
FireMalt
Super Hero Member
Offline Offline
It is what it is...
View Profile Email
« Reply #3 on: July 31, 2009, 10:08:16 PM »
You have to place the vinyl in a way to where the left pinch roller is at the edge of the vinyl... the Graphtec uses the pinch rollers to measure the width of the vinyl, no matter what you tell your cutter's software. So if you only have the left pinch roller in the middle, or 3/4 to the left... this would most likely be your issue.
I'm not partically joyful about the way that works myself, as I think it wastes too much vinyl, but what are ya going to do?? Wink
Logged
GraphTec CE5000-60|Flexi Pro 8.1|16"x20" Mighty press| Pcut 24" cutter as a spare.
Speedoggy
Super Hero Member
Offline Offline
Skeeterlost
View Profile
« Reply #4 on: July 31, 2009, 10:26:05 PM »
What ya going to do?    Go into background settings and disable it...  I never use it,  just one of those frills that I just don't use.
Logged
Graphtec FC7000MK2-75  Flexistarter 8.5  Toshiba laptop Windows XP
FireMalt
Super Hero Member
Offline Offline
It is what it is...
View Profile Email
« Reply #5 on: August 01, 2009, 12:30:29 AM »
teach a grasshopper...
Logged
Brandon_Davis
Administrator
Hero Member
Offline Offline
I LOVE TO CUT
View Profile Email
« Reply #6 on: August 01, 2009, 12:56:04 AM »
Learning to manipulate a graphtec to effeciently uttilize vinyl only gets better with experience!
Logged
Brandon Davis | Support Specialist | US Cutter | 1-888-298-8143 x113 | www.uscutter.com
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
