sarconastic
« on: March 27, 2009, 01:01:33 PM » |
I was sitting here trying to figure up my expenses on a few decals I just made, and thought why not just make a spread sheet that does it for me. So I sat down and figured out the formulas and here ya go. I have attached the Excel file here.
I was going to get a little more advanced, and I am up for suggestions. It will let you put the Name of the vinyl, your Supplier, the width and length, then it calculates your cost per square yard, foot and inch. Then at the end you can put in a length and width for a sign or decal and the number of color layers and with let you know the cost per decal/sign.
It's basically a running list of your materials with some calculations in it. So you get a new roll, you put it in the sheet while you have the invoice handy and then when you need to know what a project it going to cost you enter the numbers. Kind of like a mini Inventory. If you have more rolls that the sheet I sent uses, just copy a row and paste it back in below the bottom. It should copy the formulas etc into the new row.
Let me know what you think. This was done in Excel 2000, but it should open using OpenOffice spreadsheet too if you have it.
***EDIT: Updated this one to the new version,
« Last Edit: March 28, 2009, 12:10:14 AM by sarconastic »
Logged
"I may have said it, but you can't prove I meant it." Laserpoint 24", FlexiSIGN PRO 8.1, SignBlazer, Inkscape, 6 in 1 Heatpress.
fivestar
« Reply #1 on: March 27, 2009, 03:15:32 PM » |
Logged
*****Contact Me For Wholesale Printing*****
Roland SC-500 54" Printer/Cutter| GraphTec CE5000-60| 16x20 Mighty Press heat press|15x15 Mighty Press| Hix hat press| 2 Refine 24" cutters for spares.
SandyM114
« Reply #2 on: March 27, 2009, 03:48:07 PM » |
Hey, thanks! I can use this! Sandy
Logged
neron15210
Super Hero Member
Offline
Life should be lived as a play.
« Reply #3 on: March 27, 2009, 07:11:20 PM » |
thanks man
Logged
54" Roland SC500 Printer/ Cutter Daige Solo 55" laminator , 24" PCut 630, 36" Seiki, Knight Heat Press Flexi 8.1
jfought
« Reply #4 on: March 27, 2009, 10:23:31 PM » |
this is for me and the other 20 ppl that did not give thanks for all the work that you put into this. Thank You
Logged
FireMalt
« Reply #5 on: March 27, 2009, 10:43:21 PM » |
Thanks for sharing, and taking the time to create the form... I'll give it a shot in the morning.
Logged
GraphTec CE5000-60|Flexi Pro 8.1|16"x20" Mighty press| Pcut 24" cutter as a spare.
chefgary
« Reply #7 on: March 27, 2009, 11:25:24 PM » |
Thanks Gary
Logged
Splice
« Reply #8 on: March 27, 2009, 11:46:51 PM » |
thanks will check it out!
Logged
Laserpoint 48" w/ dual compass modules, four pistol splicers & a mohican screeching pump action guage - all custom
sarconastic
« Reply #9 on: March 27, 2009, 11:47:57 PM » |
Thanks everyone for the support. I figure this is one way I can give back a little bit. I filled out that last column that I forgot, and also added a check to make sure it wouldn't error out when there were no totals. I added a Sum at the bottom so you could add a couple vinyls together for a bid or whatever. I didn't change anything on the left side, so if you already put all your stuff into the old one, just Copy and paste it into the fixed one.
Hopefully it helps someone.
Logged
kmerting
« Reply #10 on: March 27, 2009, 11:49:19 PM » |
Thanks for posting this!
Logged
Cre8tiveCutter
« Reply #11 on: March 28, 2009, 12:22:14 AM » |
Thanx for this I needed something like this!
Renee
Logged
There is some consolation in the fact that, even though your dreams don't come true, neither do your nightmares!
guest
« Reply #12 on: March 28, 2009, 12:52:23 AM » |
lol where was this about a year ago when i was doing manual calcs to find this info out? lol
Logged
jfought
« Reply #13 on: March 28, 2009, 06:33:00 AM » |
would it be possible to have it total you app tape and vinyl for a job?
Logged
nonabelle
« Reply #14 on: March 28, 2009, 09:27:19 AM » |
thanks, will give it a try. thanks for u taking the time and sharing ur program with us.
Logged
Jenny, Grace, and Tracee, & Kenya R my Sistas.....
