March 19, 2010, 10:24:01 PM *
News: Happy New Year - The best forum on the planet is another year older!
Pages: [1]   Go Down
  Print
Author Topic: Factory Reset  (Read 1215 times)
signpro
Hero Member
Offline Offline
View Profile Email
« on: March 24, 2009, 07:19:14 PM »
Is there a FACTORY RESET BUTTON on the CE5000-60? The cutter will not allow me to cut in FlexiPRO or FlexiStarter 8.5 using flexi's prouction manager any more, unless I use Cutting Master 2. I keep getting a CALL GIN MODE........Whatever that means..HELP Huh? Huh?
« Last Edit: March 27, 2009, 05:05:46 PM by kenimes » Logged
FlexiPRO 7.0, Graphtec CE5000-60, Gerber EDGE.
Mr Peabody
Super Hero Member
Offline Offline
View Profile
« Reply #1 on: March 25, 2009, 05:27:35 PM »
I needed to rest mine and can't remember what the tech told me. If you go to their website send them an email they might tell you which buttons need to be pressed. They need to be pressed at the same time. Ugh - I just can't think of it right now. I called them and they were very helpful.
If you find out please post it.
Peabody
Logged
If you teach a cannibal to use a knife and fork, is that considered progress?
Graphtec CE5000-60 - - Vidar 54" Latitude 600e Scanner - 48" HP Designjet 800ps Plotter -  LXi 8.5- Inkscape - AutoCad Architect 2007, 2008, 2009 - Windows xp Pro SP3 - 3 TB WD Storage - Networked w/ MioNET software.
signpro
Hero Member
Offline Offline
View Profile Email
« Reply #2 on: March 25, 2009, 07:57:10 PM »
Well I figured out.....It was the HP-GL code. After I did the reset, it was all down hill from there! Im also running the Graphtec on serial cable instead of USB. I went ahead and tried to contour cut after the Gerber Edge and WALLA IT WORK.....3 Peeing Calvin's in a row Grin!!  YES!! I about pissed my pants!
Thanks for listening.....
Logged
Mr Peabody
Super Hero Member
Offline Offline
View Profile
« Reply #3 on: March 26, 2009, 08:01:42 AM »
Did you find out what buttons reset the Graphtec? I'm still trying to get it to contour cut.
Logged
Mr Peabody
Super Hero Member
Offline Offline
View Profile
« Reply #4 on: March 26, 2009, 12:52:01 PM »
I just found the email from Graphtec Tech. Support on how to reset their plotters.
On most of our printers/plotters, turn power off, hold down the "up" arrow button (^) and turn the power on while holding the button.  NOVRAM will begin and just follow the queues.
Logged
signpro
Hero Member
Offline Offline
View Profile Email
« Reply #5 on: March 26, 2009, 06:38:49 PM »
Someone should STICKY this!!! good find  Thumbsup
Logged
signpro
Hero Member
Offline Offline
View Profile Email
« Reply #6 on: March 28, 2009, 09:29:12 PM »
Sweet! Thanks!  Thumbsup
Logged
Frosted Images
Hero Member
Offline Offline
teboatwright@hotmail.com frosted_images@yahoo.com
View Profile WWW Email
« Reply #7 on: April 29, 2009, 07:07:10 AM »
Will this work with the Graphtec FC8000? It seems as if the Plotter Controller always show Error2009 on the plotter when I send a command after I updated the plotter firmware to 1.50v
Logged
Gateway Notebook  32 Bit Vista, Acer 64 Bit Desktop, Vinyl Master Pro 2.95v, FlexiSign Pro 8.1v, Photoshop CS3 Extended, Illustrator CS3 with Cutting Master 2, Graphtec FC8000-75, and a Copam CP2500, UScutters 6in1 Heat Press
kenimes
#1 guy in America
Super Hero Member
Offline Offline
View Profile Email
« Reply #8 on: April 29, 2009, 06:44:20 PM »
I heard it should, yes.
Logged
Frosted Images
Hero Member
Offline Offline
« Reply #9 on: April 29, 2009, 08:53:47 PM »
It does. I tried it anyway. How do you convert back to the original firmware?
Logged
Mr Peabody
Super Hero Member
Offline Offline
View Profile
« Reply #10 on: April 30, 2009, 11:05:54 AM »
I don't think you can go backwards with the firmware. Once it's done I think that's it. I'm not 100% sure.
Logged
Frosted Images
Hero Member
Offline Offline
« Reply #11 on: April 30, 2009, 12:07:41 PM »
Thanks. I'm having problems sending settings to the plotter from Cutting Plotter Controller. It always shows Error2001 twice on the plotter. So i have press the Enter key on the plotter twice to clear and accept the command.
Logged
fivestar
Super Hero Member
Offline Offline
Contact Me For Wholesale Printing
View Profile
« Reply #12 on: April 30, 2009, 01:07:38 PM »
Give Graphtec a call (800) 854-8385
Logged
*****Contact Me For Wholesale Printing*****
Roland SC-500 54" Printer/Cutter| GraphTec CE5000-60| 16x20 Mighty Press heat press|15x15 Mighty Press| Hix hat press| 2 Refine 24" cutters for spares.
Pages: [1]   Go Up
  Print
Jump to:
